Hey, ive been eyeing off a set of nismo floor mats for my 34, only thing is that theyre for a GTR and not a GTT.
To me they look similar and i dont see why they would be different, but dont wanna spend the coin on stuff that doesnt fit...
Might be a dumb question but meh
Cheers
  • 3 weeks later...
Update:
I can now confirm that R34 Gtr floor mats are all the same except the drivers side..
Doubt anyone will need this info, they still look good just the drivers side one is a slightly different shape, causing it to not fill in the whole floor properly.
  • 1 month later...
Well I had the same "dumb" question as you. So this helped me a lot!
Is the difference that indent on the right side by the foot pad?
Where were you able to get them from? I'm looking on nengun: https://www.nengun.com/nismo/floor-mats
And it's 243 AUS but everywhere else I look is almost double that price, while Nismo's site has it for almost triple. So I'm confused on Nenguns price
Good to hear, and yeah its the indent on the drivers side,
Which as i have now learned is due to the AWD of gtrs which makes sense.
I ended up Paying close to $350 due to shipping,
I got mine from Trust Kikaku: https://trust-kikaku.myshopify.com/products/nismo-floor-mat-set-bnr34-660111024?_pos=2&_sid=becb204a3&_ss=r
Base price of around $213 AUD shipping $130ish for me i think, and they were at my door pretty quick. If you havent used nengun before, sometimes their shipping times are a bit long, i order a bunch of Oem trims and badges off them in mid july last year and most of them didnt arrive to late September/October. Despite that i would still use them.
Theyre not cheap floor mats but i love them, my old s1 and s2 floormats were in very good condition but the nismo ones with metal badges are just a worlds difference.
Oh I see, I forgot to factor in shipping so the prices are making more sense now. Thanks for the tips! Definitely agree the metal badges are oh so lovely. Looks like I should go through with it and grab me some!
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
