G'day Guys,
Im looking to fit some custom 4 stud rims on my car to remove the need for wheel spacers on my front rims.
Im either going to have to go take some specific measurements to get the wheels to fit or the company reckons if I can just ID my front brake calipers they will be able to get the rims to fit.
The current front brakes were installed by the previous owner so I'm not 100% what they are. I suspect either Z32 front calipers or R33 gtst brakes. Is there any way to ID or tell the difference between them or are they the same etc?
https://www.sau.com.au/forums/topic/483384-nissan-front-brake-swap/
Z32 calipers (without any sort of dogbone spacer to push them out to suit a larger disc) suit a 280mm disc. With a spacer, these can be pushed out to suit 324mm discs. Same with R32.
R33 calipers suit a 298mm disc. These are seldom spaced out because it is hard to do it decently.
R34 calipers suit a 310mm disc. I have never seen these spaced out.
The differences in these radial dimensions are all in the legs of the caliper. The body of the calipers are almost (if not actually) identical.
  • Like 1
On 28/02/2022 at 9:45 AM, Duncan said:
Got a picture of the calipers?
Also, knowing the diameter of the discs will help too.
That's the pic of them without removing the wheels yet (am at work). Plan on checking closer today. I'm convinced they are one of the variants of the Z32 brakes.
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
