Hi all,
Recently my manual 1997 R33 GTST decided it doesn't want to start anymore. A loud single click can be heard from the starter but it doesn't turn. Battery had a dead cell due to an unrelated parasitic draw issue. Replaced battery, still no go. Occasionally jumping works.
I've pulled my starter off and I can't find any exact replacements for it. It's Nissan part number 23300-20P11.
I've found OEX part BXS0104 which some sites say 'should' fit, some don't.
The main difference I'm concerned about is that the starter that I pulled off is an 8 tooth starter, the OEX and all the others I can find listed for R33 GTST are 9 tooth.
Cooldrive apparently stock an 8 tooth, but it's only 0.8kw whereas mine is 1.4kw.
Are they interchangeable? Did someone do a dodgy swap on my car in it's previous life?
These are all the starter motor part numbers between genuine Mitsubishi and Hitachi OEM Nissan ones that are interchangeable:
23300-AA300
23300-20P10
23300-20P01
23300-20P05
23300-20P11
23300-AA111
23300-AA112
Kudos have the 1.4kw genuine latest 23300-AA300 one.
http://www.kudosmotorsports.com/catalog/starter-motor-suit-nissan-skyline-rb26dett-p-2055.html
If you want to be a budget arse this will fit from Sleeka in Adelaide:
https://sleekaspares.com.au/product/starter-motor-suit-rb20-rb25-rb26-rb30/
  • Like 1
  • Thanks 1
23300-AA300
23300-20P10
23300-20P01
23300-20P05
23300-20P11
23300-AA111
23300-AA112
Thanks BK, much appreciated.
No worries. For comparison the last time I purchased a genuine starter I got the lastest revision Hitachi 23300-AA300 model back in mid 2018 from RHDjapan for $690 + DHL freight from Japan, so the Kudos price is about right thesesdays for genuine.
I waste money all the time though on being "genuine" with GTRs and all that, so the Sleeka spares one will probably do you fine to save a dollar.
I replaced my starter end of last year with the oex and haven't had any problems. Just be aware there is 2 posts on the solenoid that the starter wire may work on one and not the other.
Well I got the new starter, got it installed, figured out which wire was the ignition trigger and it's presenting the same issues as the old one. Solenoid clicks when I turn the key but nothing.
Battery voltage drops from 12.4v to 10v when I attempt to start it but still nothing. I've checked fuses and attempted jumping.
I disconnected the power from the starter and just left the ignition wire connected. Same behavior and voltage drop.
I'm a bit stumped. Seems like the starter isn't getting any power?
It could also be an earth issue so check the engine block is well earthed to the battery.
You said in the first post you changed the battery, right? Did the symptom change at all when you did?  You can have them die so they seem to have a full charge but they can't deliver serious current
  • Like 1
Not sure if this is related. I recently had a issue with the car not starting randomly. starter motor clicks but no cranks. did the all the usual troubleshooting steps with no luck. the only way to start was via jump starting with another battery.
The issue resolved itself when i reverted the ECU back to stock whilst fixing another unrelated problem. This had got me scratching my head. Would love to get a second opinion.
Use a multimeter to check for continuity from engine block to chassis and battery negative post to chassis. Sounds like a grounding issue.
The factory ground straps are generally worn or not refitted properly after engine swaps/removal. I usually make 2 new ones and never have an issue again.
Edited by robbo_rb180
  • Like 1
Alright. Took the battery to Supercheap and according to them it's reading 12.7 volts and slightly higher CCA than it's rated for.
Cleaned up the earth points in the engine bay. Engine has been replaced and all the leads look new but I roughed them up a bit with a wire brush same with the cable for the starter, still nothing.
The voltage reading from the relay box in the engine bay is different to voltage reading directly from the battery. What's more when I turn the key the relay box voltage goes from 12.7 down to 8 when "on" and then down to 0.6 when I try to start it. Once the ignition is off it takes the relay box voltage reading a minute to build up again, but quickly testing the battery still reads above 12v.
Also, if I remove the power windows fuse, the voltage increases. Still won't start without this fuse. Car jumps just fine if I connect the jumpers to the relay box and will keep running when the jumper leads are removed.
I'm guessing this means there's something between the battery and starter that's causing a voltage drop. I'm also curious about the power window fuse. It's not an insignificant drop. Could the issue be somewhere along that line?
  • 1 month later...
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
