NPC 10" Organic and call it a day, if you like something for more abuse like clutch kicking, etc. then a NPC 10" Carbotic would be perfect.
inb4 Nismo Super Coppermix brigade comes in.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
