Hi all,
Owing to a recent attempted break-in to my R34, I'm trying to install an alarm. I should stress that I have never done this before, I'm relatively mechanically inclined; electronics... well, I've done some basic things with relays and switches before.
Why am I not going to a shop to do this? Well other than it being difficult because I live in Japan and have few contacts, I would quite like to set this up for the learning experience. When I ship this car back to the UK I will have to install a UK-compliant alarm, so would like to know how to reverse the installation.
I'm going to be a bit withholding on the information regarding some specifics, as, well, this is a public forum.
I'm so far just labelling everything and reading through the manual, and the first thing I have noticed as a potential problem area is as follows:
Connect the alarm defeat wire to a system that activates when the car is unlocked, i.e. hazard lights. So, the skyline seems to do nothing when unlocking the car from the inside, apart from the obvious of powering the lock motor. I do hear a relay click inside the car when unlocking/locking.
Is anyone aware of the systems that are powered when unlocking using the factory remote?
https://www.sau.com.au/forums/topic/483439-r34-gtt-alarm-install-help/
So....there's your answer.
But..... normally you do not do it this way. Normally the alarm has its own remote and the alarm has an output when you disarm it that signals the car's locking system to unlock. Not the other way around, like your alarm's instructions seem to indicate.
Why not buy a UK suitable alarm and install that?
I found, with the help of @tsuokun, that the hazard flash was only a feature on S2 R34s, it can be retrofitted to S1 but the Nissan/Altia components appear to be discontinued.
It's possible to use an aftermarket kit which is apparently popular here.
Tsuokun mentioned the differentiation of pulses for unlocking/locking, that's why there's a need to tap the hazards. So I've basically just gone and got an aftermarket retrofit kit for it.
In hindsight, yeah you're probably right. But a more sophisticated alarm would be more difficult for me to install, one would think. Plus I would like to get something in the car ASAP. Cheers
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
