My internal door handles were a little scuffed, So I thought I would try out wrapping them in Carbon Fiber effect Vinyl. I checked ebay, and they all seemed a little dark, but outside of ebay they were considerably more expensive, and this was my first attempt; so I went with something easy and cheap.
An example of how they looked before.
And after the wrap.
I also did the drivers side. I wasn't sure if the wrap would look better with the direction going up-down or sideways. I meant both to go up, but I wasnt paying attention, and now the drivers door wrap goes sideways. Looking on the positive side, it gives me a chance to choose which way looks best. Its a toss up for me, so others opinions are welcome. ANd it will be easy to remove the one I dont like, and do it again.
I think the marks are scuff marks when I carried them from the apartment to the garage. I am guessing a wipe down will get them back to 100%.
As i said, this was my first go at Vinyl wrapping, and I have to say, it was dead easy, the Vinyl was very forgiving, heating the vinyl made it almost like glad-wrap stretchy; I used a heat gun, but it was actually almost too strong and a hair dryer might even be better. I would of gone for a lighter wrap, but this dark one (and it is almost all black) was simple to order on eBay. Its "7D" which I think relates to how glossy it is; but I dont think its all that.
After seeing how black it is, and how easy it was, I am thinking to do the rear boot-lip spoiler in this carbon Fiber effect wrap; on my black car.
  • Like 3
remember I said how forgiving the wrap was? Watch how many times this professional wrap guy places and removes and places and removes over and over, when doing a bonnet.He does make it look like a DIY with minimal tools or experience.Almost makes me wish I did not have a black car. Almost ;)
He does make me a little more impressed with the fact my eBay wrap is just so dark. He also makes it clear my external wrap of the spoiler, will be susceptible to water getting into/under the wrap layers.  But I probably have enough wrap to redo the spoiler 3 times at least. And I can always fall back to my original idea of using Anthracite PlastiDip instead. I have 4 cans of Anthracite in prep of doing my stock 19" wheels. It has become clear the Anthracite would really look good with the a glossifier (and maybe even a metaliser), but that would double/triple the cost and effort.
PS: its 52min long, so I watched at x2 speed and jumped some of the "filler"
Edited by Vee37
Just an FYI, in case anyone wondered "what the spoiler would look like in Carbon Fiber". The weekend before last, I put some of the wrap on the rear spoiler. I actually did a really shockingly bad job on it, but now know how to avoid all the mistakes I made, and I have plenty of wrap left for another attempt or possibly 3.
Anyway, I have left it on, just to see what I think of it, as at first I wasn't that much impressed. Unless you get up close, it really just looks black. Ive attached some photos to give you an idea of what I mean.
However, its actually starting to grow on me. And when I was looking for these photos (some taken a few days ago), I came across a "before" one where it was the original factory chrome, and it really looks bad to me now.
I have purchased 4 case of Anthracite plastidip for the wheels, and my next idea is to peel off the black carbon fiber vinyl wrap on the spoiler, plastidip it with Anthracite, and also do the "S K Y L I N E" in Anthracite. That way the spoiler and the text would colour match. On a side, I have already done my front grill in Gloss Black plastidip.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
