Hey guys,
i just bought a r32 gtst, my first car :D:)
I was just wondering what sorta mods should i get to improve handleing, and whats a good, decent size turbo to get ?
How much kw could i make on the gtst, before id have to get all stronger internals ?
P.S - this isnt my user account (using my mates)
ta
https://www.sau.com.au/forums/topic/48346-r32-gtst-just-bought-one/
If it's your first car I wouldn't put a bigger turbo on.
Turbz lag has an unfortunate habit of kicking in around a corner when people don't expect them... to anyone let alone first drivers.
I don't want to sound patronising. I've owned a few cars, even a v8 there but never a turbz so I wouldn't even trust myself with a fat turbz.
Personally I will be upgrading the brakes so I can do some track work to learn the car.
I'd also probably look at a whiteline kit for suspension.
http://www.whiteline.com.au/docs/fact_shee...line_R32GTS.PDF
One of the first things I'll be doing with my r32.
Oh. and also I'd make myself an account and possibly join the club :D
As for the other questions someone else will have to answer you I'm not too sure - I'd expect about 200-250kw?
I'd seriously wait for later though.
First cars and skylines = I'm scared.
JIC or Blisten coilovers are good.. so if its too low and you have to raise it to clear a defect you can just do it yourslelf..
Congrats on a skylines for your 1st car..
My first was also a skyline.. R32 GTS4.. it was a great car!
no need to touch the actual calipers on a Type-M R32. They have awesome brakes from the factory. A whiteline kit and some decent pads for your brakes are a good start.
Get used to the power (you will safely if you are sensible) then go from there.
/QUOTE]
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
