Something along the lines of a Motec hall sensor.
https://www.motec.com.au/ac-sn-crankcamspeed/sn-crankcamspeed-hs/
Not sure there is much room to mount one look at the back of the studs the way the knuckle is.  I need to look at it on the car.
That should be more help to anyone else that looks at this post.
I use the factory ABS holes and run GT101 style hall sensors on the ABS rings. Due to the high tooth count and low diameter I've reduced the number of teeth by 50%, still much better than wheel studs.
This works fine with my Motec setup, I use the rear ABS sensors for rear wheel speed.
  • Like 1
I haven't done it just yet on mine, as of late I haven't had much spare time to tinker however I believe if you expose part of the dust shield you'll be able to see the wheel studs.
This would be an ideal solution on a non ABS car, however if you wish to retain ABS then this won't work.
Or if both the above is too hard basket, just use a GPS sensor and calculate the percentage slip based on rear wheel speed vs GPS speed (similar to how AWD, 4WD guys would control traction).
Perfect, this what I was after.  Did you just use an R32 abs ring and grind every second tooth down?
I looked into g sensors and gps, but a lot of people say they react too slow, however it must work some how for the AWD guys that have no option of a non driven wheel speed sensor.
Yes, just the stock ABS sensor hole (shims needed to get correct sensor clearance) and then I chucked the tone ring in the rotary table and knocked off every second tooth in the mill.
You need to have an ECU which can do different wheel speed calculations on either end of the car, I'm not sure what you are running but Motec does it. I don't have much experience with the other brands. On the rear I just run unmodified tone rings because the teeth are larger and further apart which works for GT101's.
It's worth noting that GT101's get a bad wrap largely on missing tooth setups, which they are shit at. On constant tooth setups I've not had any dramas with them but I always have spares ready to go just in case.
  • Like 1
That's going to be hard to get right. You're doing very different calculations so the resolution available in the ECU will be critical.
You will need to spend a lot of time making sure that your driven wheel speed matches your front wheel speed, I suspect that you'll need a lot of numbers after the decimal point for this to read correctly.
Is this traction setup for circuit racing or drag/roll racing?
If it's for drag, straight line business see if you can adapt a GPS sensor. You can then calculate slip percentage (road speed) between the drive wheel & the actual position of the car.
For circuit racing, you would ideally want both front wheels fed in vs. the rear driven wheels.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
