Feels like it's a box out affair now.
Nearly feels like the throw out bearing has been installed backwards (hence the noise you've mentioned). A single disc clutch should not make any rattling noises at all.
Could be onto something there
Thank you for all the help guys, since I backed the pedal stopper off a bit and made sure there was a bit of free play at the top and it's driving a lot smoother and gears are selecting without hassle. It must have been more adjustment needed like a few suggested. After the clutch has bedded in a bit I'll check it again.
I sent the videos with the sound to ACS and they said this:
"What you are experiencing is harmonic noise and nothing to do with the bearing. The Australian engineers have said it sounds like gear noise/gearshift rattle
This can happen  on some vehicles and depends on the condition of everything else. There may  be some worn  bushes in the linkage which could be cured by replacing them or some gear rattle which may be 'dampened' with some tougher gearbox oil.
Edited by Almera96gtin15
  • Like 2
well, massive thumbs up to ACS for taking the time and getting the right people to look/listen to it. Goes to show local support is worth it's weight when you have an issue.
  • Like 1
Yes mate I'm happy with their response to my queries, it's difficult to diagnose obviously without seeing the car in person. They allowed me to get in contact to pass onto engineers.
It made sense to me afterwards to take the clutch pedal pin out, let it take the pressure off the rod which moved out slightly, and adjust from there, with a bit of play in the pedal before engagement.
Obviously I'm going to go normally until everything is bedded in, I treat all my cars with respect anyway.
Cheers lads, this forum is a good community, hardly anyone replies in the UK forums like they used to do.
It's much appreciated
  • Like 1
Everyone too busy going to get pissed at the pubs and hitting music festivals.
My Aussie mates living there doing just that lol.
Yeah lol probably.
Can I just ask if anyone knows obviously.
With the adjustment on the pedal rod maxxed out, will it cause any problems with anything? (picture on page 1)
I made sure the pedal had a bit of play before it moved the rod also.
I suppose I could go back a bit and see if the gears still change smoothly,
What do you reckon?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
