JoKeR33GTR Posted April 12, 2022 Author Share Posted April 12, 2022 IMG_0263.MOV A Little update have some play in the steering rack can This be the Problem ? Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7963137 Share on other sites More sharing options...
TXSquirrel Posted April 15, 2022 Share Posted April 15, 2022 I don't think that's your issue. If the problem is with a worn steering rack, you will get vibration or clunking noise from turning, and regardless whether torque is sent to the front or not as you described. If you didn't have someone else grabbing the steering wheel as you shook the tie rod like in the video, there would always be a bit of play. Or could be that your steering rack bushing is very worn, either way that should not be the cause based on what you initially described. Like others mentioned, it could be the plates in your transfer case. A small bottle of friction modifier costs $10, and it only needs an ounce of this stuff per quart, it's a cheap way to find out if the issue is with the plates in your transfer case or front diff. Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7963223 Share on other sites More sharing options...
JoKeR33GTR Posted April 15, 2022 Author Share Posted April 15, 2022 Ok Thank you ! can you recommend a friction modifier? Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7963226 Share on other sites More sharing options...
TXSquirrel Posted April 15, 2022 Share Posted April 15, 2022 I used Redline before, but it's common fluid and if you Google you can find a dozen different brands out there, so just get whatever is available local to you. Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7963228 Share on other sites More sharing options...
JoKeR33GTR Posted April 30, 2022 Author Share Posted April 30, 2022 Hello , A Little Update .. I added the red line oil to the transfer case and still have the same problem. I checked the front differential and can't really find anything there either... I looked in with an endoscope and will show you the pictures! sorry for the bad Quality .. IMG_0386.MOV Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7964671 Share on other sites More sharing options...
GTSBoy Posted May 1, 2022 Share Posted May 1, 2022 Don't know if there's anything to see. Seeing as those photos will be on a memory card.....why not upload them direct to the thread? Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7964676 Share on other sites More sharing options...
TXSquirrel Posted May 6, 2022 Share Posted May 6, 2022 Yeah I couldn't tell if anything was off based on that. Like others said, now it seems like it could be the transfer case on its way out. On a R32 the AWD fuse can be pulled to test, is there a way to disable AWD on a R33 to test? Link to comment https://www.sau.com.au/forums/topic/483521-vibration-when-power-send-to-the-front/page/2/#findComment-7965016 Share on other sites More sharing options...
