I don't think that's your issue.  If the problem is with a worn steering rack, you will get vibration or clunking noise from turning, and regardless whether torque is sent to the front or not as you described.  If you didn't have someone else grabbing the steering wheel as you shook the tie rod like in the video, there would always be a bit of play.  Or could be that your steering rack bushing is very worn, either way that should not be the cause based on what you initially described.
Like others mentioned, it could be the plates in your transfer case.  A small bottle of friction modifier costs $10, and it only needs an ounce of this stuff per quart, it's a cheap way to find out if the issue is with the plates in your transfer case or front diff.
Hello ,
A Little Update ..
I added the red line oil to the transfer case and still have the same problem.  I checked the front differential and can't really find anything there either... I looked in with an endoscope and will show you the pictures!
sorry for the bad Quality ..
Yeah I couldn't tell if anything was off based on that.  Like others said, now it seems like it could be the transfer case on its way out.  On a R32 the AWD fuse can be pulled to test, is there a way to disable AWD on a R33 to test?
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
