Anybody have any recommendations of gear oil to use for break in period? I heard of people using Redline MT-90 but curious if people have any other opinions. The transmission is brand new from Nissan.
Cheers.
https://www.sau.com.au/forums/topic/483528-rb25-neo-transmission-break-in/
On 4/8/2022 at 3:15 PM, joshuaho96 said:
Wasn't there a guy that mentioned having issues with running synthetic gear oil during the break-in period?
Maybe me. Transmission started whining after 3k kms at a track day.
I used the factory-filled stuff for run-in, then changed to fully synthetic Syntrans "GL4+" 75W-90 (TAF-X) at about 800kms. When my new box comes I plan to just use the Nissan GL4 75W-85 consistently.
  • Like 1
That's because you can't get the good one in Japan, being Syntrans 75w-85 GL-4.
To be honest there's nothing wrong with vmx full time, just change it more regularly. One of the Rs we're just sticking with that - VMX-M gl-4 at $50 per 4 litres.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
