Evening All,
My new money pit has finally arrived so I have now started to work on it.
However, I immediately wanted to end it all cause the car wouldn't stop beeping at me.
So here is a video made by me on how to disable the key beep.
There is no wire cutting required, and it takes 5 mins.
I hope this helps even 1 person.
-t3
  • 10 months later...
thanks for the video I did this along side your steering wheel control guide.
my car kept beeping once the the T piece was unplugged
it works on a slide so if it was sloppy like mine was you may have to either zip tie it to one side (the side it doesn't beep)
or if you follow those wires back about 100mm there is another plug just unplug it from there
in the pic it shows the zip tie and the other plug. i just left this whole piece out
thanks again your a life saver!
Hey man once again. Great to hear. I ended up doing the exact same thing (just pulling the whole thing out) as I had some dodgy wires which was causing it to go off occasionally.
I'm happy to hear your getting use out of my posts man :)
