Need a hand. I was about to start redoing my stock wiring harness for my elite 2500/P&P adaptor and can't seem to find a wiring diagram that shows what pin on the elite is connected to what pin on the stock ecu harness with the adaptor.
The Haltech adaptor wiring diagram only shows from the elite connector to connector going into ecu adaptor and not on stock ecu connector which in my opinion is useless. I know I can just presume what pin it is on based on the descriptions or test them one by one but this wiring diagram must surely already exist?
Thanks
https://www.haltech.com/product/ht-151357-elite-2500-nissan-skyline-r32-33-r34-gt-r/# and download the quickstart
then use this to work out what you need, nicely colour coded too:
Nissan_R32_R33_R34_GTR_RB26DETT_Pinout_R
  • Like 1
Thanks a lot! That's a lot more complete then what I found. Cheers.
On 4/10/2022 at 6:56 PM, GTSBoy said:
I struggle to see your problem. The stock ECU pinout diagram exists. Simply hold it up next to the Haltech one and ... presto?
Nissan R32-R34 ecu pinout's don't show all pin connections with the elite 2500. One example of this is Pin 113 which is usually a "N/C" but is connected to Pin B17 on Elite 2500. Pin B17 is surprisingly not even mentioned in the Haltech adaptor manual.
That makes for a spare DPO or ignition driver that I can use pinning directly into the stock ecu connector. It also doesn't show which grounds are jumped within the adaptor, etc.
Cheers.
Edited by TurboTapin
That's correct, there are a few pins that are not used from the Haltech that are randomly pinned into the plug/play adaptor and there are some pins that supposedly should be in series from one plug to other is actually non existent lol..
I just depinned them and connected it straight onto my own harness (Haltech -> own harness) - less mucking about.
I just wrapped up buzzing each pin and wow I see what you mean. I was rather surprised by a few oddities found. I'll toss it all into an excel and post it here at some point this week.
  • Like 1
I suppose the two best options are (in cost order):
  1. Pin the Haltech Elite direct to your OEM harness, i.e. delete the plug & play adaptor & OEM connector
  2. New harness, mil-spec dis dat, IG fame.
I'm sticking with the P&P harness but I agree with option #1. I have a feeling most unconnected wires can be solved with an undocumented jumper setup within the adaptor. I'll report back once confirmed.
  • Like 1
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
