R34 GTT Auto Nistune daughterboard. Based in South East Qld.
Found a broken CAS sensor while doing the timing belt. Looking at moving the car forward with an aftermarket trigger kit instead of using an OEM unit. Either PRP or Ross.
So where I'm at atm, Haltech said run their ECU in parallel. But I feel like the factory ECU will still need engine speed from a factory CAS to run the auto transmission. Incase you didn't know, the Haltech website says manual only because they don't do off the shelf auto harnesses. They can be made though.
Had a quick chat to the Hoff and he came to the same conclusion.
I wish Nistune had a phone number listed so I could ask if they can support modern hall effect input. Then I wouldn't need to change ECU. Most of the workshop contact numbers on the Nistune website don't ring through. Nistune still looks like their open for business because they have recent covid info on their site. I've sent them an email. Also need to speak to PRP at some stage for their input.
Kinda looking at a Ross balancer anyway. The original balancer is looking worn. Also, balancer bolt? ARP wouldn't sell Ross the bolt to include with their balancers, so they're still looking for a quality bolt to include, and so am I.
The water pump in the timing kit wasn't the same either, I went for the round hole listing from Golby's. Should I have gotten the slotted one?
I also think the timing kit should include a new tensioner spring. I didn't think to look for a new one and the original feels a bit soft imo.
May have to find an aftermarket trans controller or something. Still researching. If anyone has some info I'd love to hear it.
Edited by Draimond
Rephrase
https://www.sau.com.au/forums/topic/483536-my-r34-gtt-auto-various-questions/
Heres an alternate to the other trigger kits and many of us are using it with great success and is 1/4 the price
https://www.nzwiring.com/index.php/product/trigger-kit/
Nistune does not support other Trigger setups
Haltech elite can control automatic gearbox now already A340 & GM box support. Setup as a generic auto gearbox. Will need a patch/custom loom made & setup will need some testing.
Or buy aftermarket controller but haltech would be the go with a 2500 and do drive by wire and setup cruise control too
Edited by robbo_rb180
  • Like 1
Thankyou.
What a headache it's been, it only took me a solid day of phone calls and emails to come to the same conclusion.
From what I gathered it would be cheaper to do a basic engine rebuild and get the oil system upgraded than to get aftermarket inputs and sensor working.
Even if you go to an aftermarket crank trigger you can still use the factory cam signal. Unlike the aftermarket solutions the OEM cam signal has one tooth for each cylinder and the width of each tooth is different so the ECU can tell exactly which cylinder just hit TDC. The utility of this is probably a little questionable when all you really need is one tooth to indicate that the cam has reset but I'm sure Nissan engineers would never overdesign something for questionable benefit.
We used to list our phone number, but got bombarded with various unrelated technical enquiries so never got any actual work done. Plus I work for PCMTEC these days too.
We have a contact page, And responded to your query within the same day. OEM ECUs only use OEM sensors. Hall effect require completely different electronics to support them.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
