hello! i see a lot of people on here have done the upgrade of the OEM speedo to one that hits 320km. is this a straightforward swap, like 1:1, or is there something else that needs to be done to ensure that it works properly. i have the speedo, and the 3-din that match (nismo white face) but wanted to get some input before i actually start this.
some questions:
  1. can i remove the current equipment and just plug in the upgrades and be done with is?
  2. is there a way to bench-test the speedo and 3-din module?
    1. the speedo seems to have a 2-pin plug on the back of the driver's side
    2. the 3-din has IGN and GRN marked
    3. can i just hook those up to a 12v power supply? my fear is frying these things.
  3. Is there a way to set the mileage on the odometer to match my current count? the current one is at about 148k and the new one is at about 28k
thanks in advance!
https://www.sau.com.au/forums/topic/483550-r33-gtr-speedo-3-din-upgrade/
1. Yes, assuming they are for the same make/model
2. Sort of, you can power them up by applying 12v to the + and - pins (if you can identify them). Eg, take a battery, put a small fuse on the + side and hook it up. But that won't tell you if the gauges work, they will need proper inputs. Just do step 1
3. Not really, and there is no check. Just do step 1 and keep the old dash, if you are concerned take a pic of the klm on your old and new dash on the same day to show the delta.
Basically if they are correct for your car, it is a simple case of disassembling the dash fascia, unscrewing and unplugging the old on, and plugging in the new one. Before you do is a good time to check all the globes are present and work in the new dash
  • Like 1
thanks, @Duncan! i wanted to power them on just to get the bulbs in correctly. i am changing them to LED and if you don't get the polarity right, you have to pull out the dash and pop them out. again, i appreciate the input.
If you have a weird thing about how you don't like the insane range of the 320 km/h Nismo meters and for some reason their coloring of the 8-9k range as yellow rather than redline I'm pretty sure you can just adjust the speedo calibration resistors and replace the gauge face with whatever corresponds to your desired calibration. You could make a 300 km/h speedo that way I believe like the Impul ones that were basically identical to factory other than the speed calibration change.
  • Like 2
@joshuaho96 - it ends up working out, as the v-cam will be pushing me into the 8,800 range, once completed.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
