That's what the label on the box showed, unless GCG sent me something different inside.
I had a shop doing the installation, and they told me I didn't need it.  Not sure if it's a good idea to add a restrictor on top of another anyway, that may reduce or slow the oil flow too much.
Edited by TXSquirrel
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7963995
I don't think what you are questioning have any relation to the oil situation around the restrictor.
No, I have no issue for the past 5 years, lag, smoke, etc.  I do feel the -9s are still laggier than I expected, even with the Tomei cams I have that come with very different centerline than factory cams.
I have stock oil pump.  A high pressure oil pump will not impact the oil restrictor.
Mine is dyno tuned to 20psi, but I only run 15psi most of the time.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964088
The questions I asked are I think relevant to the oil restrictor because it seems people that tend to have problems with Garrett turbos:
a) experience more lag and/or smoke because of over oiling
b) run high pressure pumps
c) run high boost which is probably why they have the high pressure oil pump.
One theory is the high pressure pumps over power the in-built 1.0mm restrictors causing a) above and so require the HKS 0.8mm restrictors.
Anyway thanks very much for all your replies - you have really helped me make up my mind not to use secondary restrictors.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964095
Put your factory cams back in. Just gonna be laggier with those Tomei lumps.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964098
The difference in restrictions you're talking about is negligible on a turbo oil feed.
I run the original HKS GT-SS which are metal ball bearing -9 equivalent. They came with restricted banjo bolt from memory, not an actual restrictor in the turbo. There was nothing in the turbo chra to limit oil flow.
The newer -9 sounds like the oil restrictor feed is in the chra for exactly the reason of not needing any restrictors in the fittings or line, so you can't stuff it up.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964099
Doesn't the turbo call for a specific oil pressure at the feed? So in theory at least a super high pressure oil pump will need more restriction and a low pressure oil pump would need less restriction. How much that actually matters in the context of real parts I don't know.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964110
Not oil pressure- oil volume. As long as it's not the volume requirement for a journal bearing turbo as they require far less oil volume on a ball bearing cartridge.
Read what I posted. The turbos oil volume is regulated by the restriction too. On my HKS GT-SS it was to use a different supplied banjo bolt as the restriction, as in say remove the standard banjo with a 5mm odd hole (stock journal bearing heap of shit) vs one with a smaller (1mm or so) hole for a ball bearing cartridge.
If the new -9 are restricted as implied at the chra to the correct size it doesn't matter what oil feed bolt you use as long as it's bigger than the chra oil feed restriction fitting. I've noticed Precision doing exactly this on their ball bearing cartridges to stop muppets getting the oil feed sizing wrong - just use a -4 line to oil turbo feed and it will be correct as the chra fitting has been restricted for you correctly.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964122
I checked online and Garrett seems to suggest that at warm idle minimum oil pressure at the inlet needs to be at least 15 psi and at redline no more than 45 psi. Can you really separate oil pressure and flow rate in these systems? I assume that when the spec says a certain oil pressure it implies a certain resulting pressure drop across the CHRA and a resulting flow rate.
https://www.sau.com.au/forums/topic/483560-gt2859r-turbos/#findComment-7964160
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
