Heya folks,
Just got home from a drive and my turbos decided to shit themselves.
I actually had it up on the market but now it looks like that's being put on hold till the issue is fixed. :(
The car is in amazing condition and I don't want to do any big single upgrades or anything like that. Since I'm pulling them out may as well put something a little better in there.
Any recommendations on some decent twins that aren't going to break the bank?
I don't want to have to change the manifold or anything like that so it would have to be something that bolts straight in.
Thanks in advance!
https://www.sau.com.au/forums/topic/483574-twin-turbo-upgrade-r33-gtr/
On 20/04/2022 at 3:11 PM, robbo_rb180 said:
Either rebuild what you have by @hypergear, find a second hand set or 2860-9 upgrade.
Exactly. 2nd is quicker to do and might cost a little more, and you will get 20% more whoosh.
You'd be mad to convert a GTR from twins to single these days unless it is for genuine race only use
https://gcg.com.au/turbo-charger-kit-nissan-rb26-low-mount-iwg-gt2860r-9-xtr000908i.html?ref_cat_id=Turbo-Upgrades-Kits-Petrol-Turbocharger-Kits
This what you boys mean by the -9s?
Also, while we're here - since they're blown and the car is sounding like a hilux, does this mean I shouldn't be turning it on at all and tow, or is it ok to not hit boost and drive it to the workshop?
Edited by Mlads33
I wouldn't allow the engine to turn until you've verified that you haven't gotten a bunch of ceramic bits from the turbine going backwards from exhaust gas reversion. Letting off at high rpm you can see the manifold pressure reach high levels of vacuum.
Edited by joshuaho96
Yes, those. That kit includes the slightly different oil drain fitting you need.
And no, don't run or drive it. Depending what has happened exactly there could be crap all through your oil. Also, it is worth having someone check it out and make sure turbos are the only issue, they don't generally die on their own and there is a chance they can do other damage
Why?
can always put the shit lag wagon twins back on.
A weekend in the garage and it’s “as it was as Nissan intended” or some other dribble that GTR guys love to froth over.
As Brett said, -7’s/-9’s or if you want a bit more poke a set of -5’s. The as it’s been for the last 20 years.
  • Haha 1
It's not 2010 anymore mate, the world has moved on. An R series GTR is no longer for making big power out of, breaking parts that can no longer being replaced, leaving in the garage for years, then repeat.
It is for keeping standard as possible, putting genuine nismo accessories and maybe some period rays wheels on, and shipping to the US when you win GTR lotto.
People don't have to like change but it happens anyway. Ask anyone who wanted to own a GT Falcon or even a Torana in the last 20 years.
  • Like 2
Since the turbos are coming off, might as well pull out the motor for ease and at the same time add in a head drain/sump breather, Nitto oil pump, extended baffled & gated sump, fresh bearings, ARP stuff top to bottom, Nitto OR Tomei head gasket, all fresh seals.
If money permits, a Samsonas too.
Who the f**k pulls the engine out to change turbos? I can have a set of turbos out of a gtr in about 2hrs,
better ring maatouks, crd, jem and etc and let them know what GTRs are for now because they’re building more then ever and finished examples are fetching huge money
  • Like 1
A lot of workshops I talk to don't even do intake plenum/collector with the engine in the car.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
