I hope I've posted this in the right section. Looking for some insight into how I might fix this issue.
I've included a video of the speedometer needle issue.
https://youtube.com/shorts/8R-IJ91goag?feature=share
Some info on the car:
- 98 GTT converted to 6spd CD009
- Nismo A/T cluster from back when it was AT. This was working perfectly up with the CD009 until one day the needle started acting up.
- shutting off the car and turning it back on usually fixes the problem but going full boost has a tendency to cause the speedo needle to lose connection (like 60% of the time).
Tomorrow I will remove the cluster and inspect the plug in terminals for wear/corrosion and re-install to see if anything improves. I was wondering if it could also be related to the wheel sensors?
Any advice would be appreciated
https://www.sau.com.au/forums/topic/483590-nismo-speedometer-intermittent/
If that's where your speed signal is coming from, then yes, it could be. But, given that I can't see how the speed signal would be coming from the wheel sensors, it would seem unlikely.
  • 3 weeks later...
