Guys, a couple of things please
  1. TPS voltage has been at 0.36v for years (have ECU Talk readout) as could not get at it to adjust it and tuner said not a problem. Engine runs fine but now have front of engine apart and have reset to 0.44v closed and it reads 3.76v fully open. Is this about right? What is consequence of either low or high voltage when closed?
  2. Took opportunity to install adj ex cam gear. What is the go here? Currently run a TD06-25G, which is a bit laggy but once on full boost (20 psi) around 4000 RPM really gets going and holds boost through to 7800! Am led to understand retarding cam gives better turbo response as I would like it to come on a bit earlier. Is this correct? If so, approx how many degrees?
Thanks
https://www.sau.com.au/forums/topic/483595-rb25det-queries/
You should have left it as is! Your tuner would have already calibrated the voltage range in your ECU.
If you play around with it your ECU won't know what a WOT and idle condition is anymore. Since you've played with it, you will need to recalibrate your TPS in your ECU (I recall you're using a Haltech) - not a hard task, but you've essentially just undone his/her work.
Try ret4rd it by 3~5 degrees however you'll need to take some timing out in your peak load area - best to be done on a dyno to load hold and knock detection.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964381
OK thank you. WOT? I'll give it a try and can always reset back to original voltage. I think the voltage has changed as bit since it was tuned 8 years ago so that's why I reset it. Its a Z32 ECU with Nistune board. Yes understand re the adj cam gear and that I will need to check timing after adjusting. Mate David Zilm has a private Dyno Dynamics I can use.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964384
WOT is wide open throttle, Nistune allows you to adjust the minimum voltage before the idle strategy is enabled.
Easier to leave it how it was before as the TPS calibration in Nistune isn't as straight forward as a modern ECU.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964387
OK thanks for all that info, however, what you are saying is that the voltage is not that important at tuning but I constantly see posts here saying TPS voltage should be between 0.45 and 0.5 v.
Re the ex cam gear are you saying that 3-5 degrees boofhead will improve turbo response, which I assume means boost will come on at lower RPM. Any idea by how much lower? I guess one tooth is about 8 degrees hence the need for a vernier gear.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964434
Yes, if you're using a PowerFC door stopper or a stock ECU :)
If you're using a configurable one, you can set whatever voltage is the floor for the the ECU to you know you're at 0% throttle to enable the idle strategy and/or decel fuel cut.
Really hard to say, best way is to incrementally ret4rd it on the dyno and graph the differences between runs.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964435
OK thanks that all makes sense and I now understand the difference. Will reset voltage back to original value.
Again makes sense so i'll try that on the dyno. Assume as cam is retarded CAS needs to be advanced the same amount to maintain correct static timing?
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964436
Theoretically you shouldn't move it, because if you do your TDC will be offset.
By ret4rding the cam gear, you're just ret4rding the exhaust cam and it's unfortunate the CAS is running off the exhaust cam.
If you resync it, then your entire timing map will be off.
Those are my thoughts, happy to be corrected by someone at least 3x smarter than me @GTSBoy lolol
  • Confused 1
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964437
Cam timing is not ignition timing - completely different things.
Regardless of where adjustable cam gears are set you still set up the crank angle sensor as normal with a timing light to get correct engine position against the crank - It's the whole point of adjustable cam gears so the outside cam gear teeth don't move from the factory position relative to the crank to change cam lobe location.
Ignition timing is relative to where the crank and therefore pistons are (engine position), not relative to cam lobe positioning.
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964439
I think this, because
(actually, not because of this)
because that's not true. He's adjusting the cam gear, not the crank gear.
But also I disagree with Ben, because
This is not true. The CAS is driven off the centre of the end of the camshaft. Therefore the CAS is in time with the camshaft. The gear remains in fixed relationship with the crank, but the adjustable bit of the gear moves the cam foreward/backward wrt the gear, and the CAS goes with it. So, advance or boofhead the cam by 2° and you have to boofhead or advance the CAS to compensate.
Whatever the case, you don't just twist it back..... you do use a timing light to get it set right, in which I do agree with Ben.
There. I hope I haven't ruffled too many feathers.
  • Like 1
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964448
Maybe I didn't explain it in detail enough to be clear as yes the CAS is off the camshaft, but the point of it is to reference the CRANKSHAFT, not camshaft position. CAS = CRANK (not cam) angle sensor. Yes if you adjust the the inside of a cam gear the CAS will end up in a slightly different position, but the different position is referenced relative to the crankshaft for engine position.
At the end of the day we do actually mean the same thing 👍, as the ignition timing is in reference to the crankshaft, not the cam position
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964452
On 29/04/2022 at 4:22 PM, Dose Pipe Sutututu said:
There we go, I was wrong :)
Happy to admit it too, unlike Facebook - where most will argue they're right even if they're wrong!
As long as everyone's on the same page about what's going on, that's all that really matters 👍
  • Like 2
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964464
On 30/04/2022 at 12:43 PM, Duncan said:
I can't take it any more. Autoreplace for retard has been removed. No idea why it was ever there.
Oooh man! It took me way too long to work out what you were talking about. I had never heard of the term boofhead before reading this thread. I just went along with it and assumed it was a special way of adjusting things. Because people used it so confidently and GTSBoy is always so educated on everything.
It would have been pretty funny if I ended up asking my mechanic about boofhead timing adjustments
  • Haha 3
https://www.sau.com.au/forums/topic/483595-rb25det-queries/#findComment-7964674
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
