Current r33 GTR markets
So have been toying with the idea of parting ways with the HMAS boatyMcboatfase.
Whats the general consensus on the market of r33 gtr's at the moment? I have a modified one and with the spread of pricing i have seen, its hard to gauge a sensible parting price.
Details are
-2.8 Spool kit (drag pro I Beams with the rod bolt upgrade and big pins)8.8:1 comp.
-Nitto Drag head gasket
-Nitto engine gaskets and seals
-Arp head and main studs
-Billet pump gears
-Nismo sump baffles
-Drilled oil returns, smoothed and enlarged head returns, usual restrictor
-Nismo engine and tranny mounts
-LS1 alternator conversion
-Breather tank/washer bottle combo
-Kelford 182-B cams, adjustable cam gears
-Supertech everything including inconel +1mm exhaust and SS +1 valves, titanium retainers, dual springs ect ect
-Extensive head work and squish mods
-460 intank lift pump into undercar surge with 2x044 E85 pumps into plazmaman rail and 2200cc's, turbosmart reg
-Turbosmart progate 50, GTW3884R (bigwheel) and manifold
-115mm cooler
-4" front to back drain pipe
-JB full monty 10" clutch
-S/Cut helical gearset in stock box
-GKtech FUCA, RUCA, Traction, RCA's, Lockout kit, Subframe bushes and spacers
-MCA pro custom coilovers
-Mech rear diff (no Vspec junk)
-Cam trigger kit and ATI big balancer, Vi-pec plugin with e85 only tune, Morristech 15amp external ignitor and splitfires (never had a spark issue)
-Turbosmart e-boost street 40psi
-M&H drag radials on stock rims
-MP original paint colour car
-Sound deadened doors, rear inner guards, rear panels, parcel shelf and rear wall/under seat area
-Genuine 85k on the car, ive owned it since 2007. Paint is in fair condition, has the usual small blemishes as the wife drives this car to work. Makes an easy 500awkw at 27pound.
Whats a ballpark sort of price do we all think?  Interior is reflective of an 85k old daily driver. Is garaged, not driven in the rain and used as its built. Have not run a full pass at our local track as I have had numerous warnings about the 1/8th speed already but generally rolls through for high/mid tens. Genuine, honest all-day 10 second traffic light weapon. Only considering this to possibly fund a ProLine powertrain for another project.
470355574_ScreenShot2022-04-28at2_32_21PM.thumb.png.7a9b9d759c000210061f681cd2c34ed9.png
This is the closest thing I've found to a valuation guide for these cars in the US. Prices are in USD. Keep in mind Hagerty is primarily concerned with stock/near stock cars and for anything modified they're not great at pricing those. Value of your mods are almost entirely dependent on what someone wants out of it. Someone like me that wants a lightly modified car is probably going to not value it as highly as someone who wants a built motor with that kind of spec.
  • Like 1
 Share
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
    • Hi Chris,   long time since your post, just wondering if you have the Pinout for the v35 stereo plugs, I bought the roem nis2 harness but it doesn’t match the v35 connector. any help appreciated, I can work out the grn and power constant. But the rest might be hard. thanks Tyson
