Hey All,
I have a R34 25GT thats experiencing high fuel consumption. I'm getting around 6-7 km/L on highway, so about 15L / 100 km. I used to get about 600+ km out of a full tank (65L) on highway so something just seems to be off. When I use the consult cable, I noticed my ignition timing has been retarded back to 5 at idle when the car has warmed up. I think it should be 15 or so. The car doesnt have any mods, and running stock ECU. Also, no codes come up when I read the ECU
Some of the stuff I've tried so far:
  • Change O2 Sensor
  • Clean AFM
  • Change Fuel Filter
  • Change coil packs
  • Change spark plugs
  • Check Fuel Pressure (seems fine according to workshop manual)
    • 41 PSI when fuel pump is primed but car is off
    • 38 PSI at idle
    • 46 PSI when vacuum hose pulled
  • Check VTC Solenoid - Clicks when 12v put across it, gave it a clean anyway and put it back in the car, but no change.
  • Check coolant temp sensor - seems to be working via Consult, and temperature guage on dash will rise up to just below middle
A few questions:
  • Can leaking fuel injectors / bad spray pattern affect timing?
  • I'm wondering if I may have skipped a tooth, but really not sure how possible that is.
I've added the logs here from nissan data scan in case someone wants to help take a look.
Really unsure what to do next, any help would be appreciated.
Thanks!
20224151332.log
Edited by _scott
https://www.sau.com.au/forums/topic/483613-poor-fuel-economy-on-rb25de/
low idle timing indicates inability of the ECU to control the idle speed down with the IACV, so it is reducing timing to get the speed down. This implies a vacuum leak, which shouldn't cause high fuel consumption (should make it run lean, if anything) but maybe the closed loop O2 control is going overboard.
Look for vac leaks with spray can of carby cleaner.
Also ponder if the air filter is too dirty. You made no mention of looking at it. Also, if that's not the cause, ponder if the cat has collapsed.
  • Like 1
It's possible that your air leak is not an external one but an internal one. Stuff like the cold start valve/intake air regulator as they get old can struggle to close properly and ends up bypassing a lot of air all the time. Your O2 sensor seems to be healthy and oscillating quite a lot. Makes me think I need to replace my O2 sensor if I'm honest, mine seems a bit lazier.
On 5/5/2022 at 3:05 PM, _scott said:
Ill take another look at all the vacuum lines. Maybe I missed something along the way.
It's not just lines. It's plenum gasket, inlet manifold gasket, TB gaskets, etc.
Whilst Joshua is correct that an internal vacuum leak is also possible, and an internal leak** could in fact result in the low idle ignition timing also, it won't cause the high fuel consumption. Well, it's even less likely to cause it than a normal vacuum leak from outside would, and even that doesn't seem like the normal result of a vac leak.
** What he really means is a dead or dirty/sticky IACV not being able to close enough to bring the idle down.
Or somewhere your intake plenum isn't flat and sucking in additional air, then your closed loop O2 control strategy is adding in more fuel to compensate for the false positive lean condition.
The above could apply to a pinched injector seal
The above above could also apply to an exhaust manifold leak, where additional air is being sucked in through a venturi effect and once again your o2 is reading baloney.
@GTSBoy  Makes sense. I'll give the carby cleaner method a try, I'm probably missing a leak somewhere. Any areas I shouldn't spray around? I assume near the spark plugs as it could ignite. I'll also take a look at the IACV and make sure it's clean. I did however clean that out fairly recently.
@Dose Pipe Sutututu I did take a look at exhaust leaks and there doesn't seem to be one. I sprayed soapy-water up near the exhaust manifold but didnt see any sign of leakage.
My valve cover gaskets are leaking, could that possibly cause a vacuum leak or nah?
Edited by _scott
Valve cover leaks are vacuum leaks in a MAF system. The degree to which that matters is likely pretty minor in practice unless you have a gaping hole that you've been ignoring but it does contribute a little.
@Dose Pipe Sutututu I dont have a smoke tester. Maybe I should go invest in one...
I tried checking my exhaust mainfold for leaks, seems fine. Took a look at my IACV, pretty clean, so doesnt seem to be an issue.
I also remove my exhaust and checked the cat, hasn't disintegrated and doesnt seem clogged.
Anybody have any idea what to check next?
ok, I bought a smoke machine thanks to  recommendations from @Dose Pipe Sutututu and found a leak instantly.
Looks like the gasket between the throttle body and intake is cracked and possibly letting air in/out.
Since shipping times are slow as hell from Japan, what would be the best way to repair this temporarily?
  • Like 1
On 09/05/2022 at 8:28 AM, Trex said:
You could try some permatex ultra grey, or ultra rubber.
Might get you out of a pinch. But there is no saving that long term.
This would be a great temporary, temporary permanent work around until your new gasket comes.
2x internet points to me! That's a bad looking crack. It could be responsible for your troubles, but it might not be severe enough. Look forward to your report back. This sort of stuff is great, because you have a problem that makes you start looking at the car, and you turn up all sorts of things that you really should fix, and you fix them all trying to solve the problem.
I order a fair amount of parts from Japan(Amayama) and it takes roughly 2-3 days to arrive in Quebec snail mail. 1 day if you pay extra.  If you're in Australia which is much closer, should take half that.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
