On 8/21/2022 at 7:18 AM, The Mafia said:
Butters, how does it drive? Can you feel your foreskin starting to peel back when its coming onto boost now?
(I have to ask because mine got snipped 😢 )
lol that is an interesting way to describe ......
Car is still not tuned yet, this was setup step prior,  so hopefully in a couple of weeks time i will have a dyno graph.
  • Like 1
I'm glad the issue was resoled by changing the valve springs. I hope to have my VCam Rb26 240z this week, but need help on wiring. The solenoid is not polarity dependent, but the cam position sensor is...
Does anyone know which lead wire is Signal Ground and SPI (shielded cable) . Haltech ECU.
I have a yellow wire with black stripe and a solid yellow wire,.
  • 2 years later...
Hi guys,
Sorry to butt in and take it slightly off course, although still on the VCAM subject.
I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs.
Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm?
I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
1 hour ago, believer said:
Hi guys,
I would be looking at the tune mate. How do you know that you have such a low dynamic compression?
I had to dumb mine down because it was too jumpy when taking off (too much torque).
What ECU? Do you need help with the tune?
I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm.
I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue.
I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
Edited by believer
  • 4 weeks later...
1 hour ago, PotatoCake said:
Not sure if any of the original members are still around, but what are your thoughts on the v cams after all this time and sorting out any installation issues, worth spending the $ on?
Definitely mate. Made my RB26 down low absolutely awesome.
  • Like 1
Very happy with mine and I think you will be hard pressed to find someone that isn't happy after installing.
Is it the best value for money vs other mods (eg 2.8 stroker) hard to say.
If you are building an all out power motor above 1000hp+++, it's probably not for you as you will want bigger cams.
  • Like 1
Currently at 380rwkw with 2860 -5's & b cams on e85, trying to make it have a bit more torque/usable power down low.
Ive googled the v cams and most sites say discontinued, is there anywhere you can still get them?
Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal.
Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low.
Boost build a bit sooner and torque rise way more when it start building boost.
Only need to deactivate the VTC past 6500/7000rpm.
Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
23 hours ago, Butters said:
https://www.nengun.com/hks/valcon-rb26-v-cam-system
no controller but most will use ECU to control anyhow
I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
