Hey everyone,
So I just finished wrapping up a build on my R33. New turbo, injectors, exhaust mani, cut and shut intake, etc...
We did some street tuning and overfilled the catch can. After cleaning up the mess we realized there was a lot of vapor coming the catch can breather. Checked the oil and it smells like fuel.
I primed the fuel rail and there's a buzzing noise coming from the injector for cylinder 3. Cylinder 3 also smelled strongly like fuel  when I removed the plugs. I'm assuming the injector got stuck open somehow, so I'm having them tested and cleaned.
Going to compression test it in two days when I get back home. Assuming it tests well an, any thing else I should do before putting it back together and starting it back up once I get the injectors back?
https://www.sau.com.au/forums/topic/483654-fuel-vapor-from-catch-can/
If there was vapor coming out due to crankcase breathing you might want to put an inspection camera down the plug holes and check for a potential glazed bore. If no.3 was getting washed down with fuel there might be some excessive cylinder wear.
Changed oil, full of fuel. Did compression test and it looks bad. Cylinders 1, 2, 4, 5 & 6 all had 80-90psi. Cylinder 3 had 155 psi. Will be doing a leak down test this weekend when I get back home. I'm guessing the tuner leaned out the other cylinders while that injector was dumping fuel into the cylinder.
So I bought another compression tester to double check.
150-160 on all 6.
  • Like 1
Sorry, I should add, you may have troubles bedding the rings on cylinder 3 if you have had an injector problem. It is probably worth getting it on a dyno to run the engine in once the injector is sorted  as it may never break the glaze on the bore with just street driving
  • 8 months later...
Just an update on this. Much more was wrong. Tuner messed up and set boost to 22psi and cut fuel like crazy working around the stuck injector. Something must have been wrong with my compression tester because I bought another one the next day and I had 50 or less psi on all cylinders except #3 and that's the one that had the stuck injector.
Tore it down and pistons 1,4,5&6 had cracked ring lands.
Almost finished rebuilding now with CP pistons and Manley rods though.
  • Sad 1
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
