On 5/22/2022 at 7:32 PM, Murray_Calavera said:
Cheapest way? Spray.
A wet kit with 200hp jets could be up and running for less then $2000. Then its about $16 per pound when its time to refill your bottle.
Ok sorry I should rephase my question. But good answer haha.
How can I make 400whp that isn't using nitrous.
Whats your budget? Maybe call Nispro in QLD for quote - they build a lot of VQ and have a turbo kit in development - but id say at least 20k to do it right - oh actually maybe do LS swap will be cheaper but....hmm  im a purist - so id rather stick to VQ35DE or whats the point lol.... just my opinion - do what u want. its your car
Edited by SuperDry2013
a blower on 6-8psi on ethanol is the easiest way. Anything more is rods and pistons.
Contact East Coast Customs as they are all over above combo
https://www.eccustoms.com/
https://www.facebook.com/eccustoms/
Did heaps when I was there with good results, factor in headers, a clutch and oil cooler too.
  • Like 1
On 5/22/2022 at 8:03 PM, Blakeo said:
Hi guys,
As the title states what is the most cost effective way to make 400whp from a vq35de in a V35 skyline chassis. I'm looking at all available options even an engine swap, price is a major factor.
Cheers.
@Blakeo the first link by @robbo_rb180 above takes you to their site, and they have a "chat" feature. Sounds like the perfect people to ask. I was a little disheartened that their Nissan page was a little sparse.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
