Hi all, l didn’t want to put anything on the forum, however l am unable to work this out and am extremely frustrated, hopefully someone can give me some good direction.
the car blew a cooler hose, since then it has developed a miss at approx 5,000 rpm upwards.
the strange thing is that it now fowls only plug number 6.
all others are fine.
changed coil packs around and same issue.
new coil loom, same. Car runs, idles and drives fine, as long as you don’t go past 5.000 rpm.
running apexi fc. Has had tune. Developed this after the tune. However was running amazing until the hose blew off.
Boost is a conservative 15.
if anyone can give me some direction it would be greatly appreciated.
regards.
https://www.sau.com.au/forums/topic/483695-r33-s15-missing-at-5000rpm-onwards/
Sounds like it had a boost leak ( the cooler hose about to pop off) and was tuned to suit that. Now boost leaknis gone tune is wrong.
Did you pressure test the cooler pipes before the tune?
  On 28/05/2022 at 1:43 AM, Killer33gtst said:
Hi,  the only thing l am confused with is at to why only number 6 is fowling???
thanks.
Expand
Do a compression test then check the injector flow. If there's per-cylinder fuel trims make sure it's reasonable too.
Yes, plugs changed, several sets now.
has had new cooler piping both sides.
turbo  side to air filter done pre tune. Intake done only a week ago. Still same problem.
Car ran perfect after tube, 232rwkw. @ 15psi.
drove it 250kms after tune, no issue. Gave it a few short drives and it, again, was perfect.
blew the intake pipe to plenum off.
once this happened it ran like shit.
changed plugs as they were all Fouled.
since then it has had the issue.
Appreciate everyone’s input.
I have seen a car foul plugs mysteriously more than others, and it turned out to be the diaphragm in the FPR that had failed, sending fuel into the plenum into two cylinders specifically.
Something mechanical has let go in the cylinder that is fouling. It would be very suprising to somehow make a tune that only fouls 1 cylinder unless you are playing with cylinder trims, which I don't think is very common on a powerFC.
You need more data available to you. Is the problem spark related? Fuel related? You may need a dyno to figure this out.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
