Hi all, l didn’t want to put anything on the forum, however l am unable to work this out and am extremely frustrated, hopefully someone can give me some good direction.
the car blew a cooler hose, since then it has developed a miss at approx 5,000 rpm upwards.
the strange thing is that it now fowls only plug number 6.
all others are fine.
changed coil packs around and same issue.
new coil loom, same. Car runs, idles and drives fine, as long as you don’t go past 5.000 rpm.
running apexi fc. Has had tune. Developed this after the tune. However was running amazing until the hose blew off.
Boost is a conservative 15.
if anyone can give me some direction it would be greatly appreciated.
regards.
https://www.sau.com.au/forums/topic/483695-r33-s15-missing-at-5000rpm-onwards/
Sounds like it had a boost leak ( the cooler hose about to pop off) and was tuned to suit that. Now boost leaknis gone tune is wrong.
Did you pressure test the cooler pipes before the tune?
Yes, plugs changed, several sets now.
has had new cooler piping both sides.
turbo  side to air filter done pre tune. Intake done only a week ago. Still same problem.
Car ran perfect after tube, 232rwkw. @ 15psi.
drove it 250kms after tune, no issue. Gave it a few short drives and it, again, was perfect.
blew the intake pipe to plenum off.
once this happened it ran like shit.
changed plugs as they were all Fouled.
since then it has had the issue.
Appreciate everyone’s input.
I have seen a car foul plugs mysteriously more than others, and it turned out to be the diaphragm in the FPR that had failed, sending fuel into the plenum into two cylinders specifically.
Something mechanical has let go in the cylinder that is fouling. It would be very suprising to somehow make a tune that only fouls 1 cylinder unless you are playing with cylinder trims, which I don't think is very common on a powerFC.
You need more data available to you. Is the problem spark related? Fuel related? You may need a dyno to figure this out.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
