Remove ac condenser, replace with 42 volt alternator from ebay, anywhere from $300-$2500
Test and adjust
My vote is high rpm reliability test of stock condenser
What is the worse that could happen?????
I've had this type of conversation lately with a couple of peeps on here.
The electric compressor is a good idea to prevent the on-off clutch problem from the compressor potentially cycling while at high revs. Granted, in the usage model of charge cooling, it would likely be stuck in the ON condition. But in the OP's usage case, it could quite likely cycle on-off when just working as an AC, even though he might be pooping out 7k rpm at the time. So, yes to elec comp on that basis.
But perhaps the better aspect of an elec comp is that you really need a 42V battery there for the alternator to run against. Now, ignoring the weight penalty of having to have another 18 cells of lead acid battery on board (in addition to the native 12V battery) (or potentially something like a lithium battery) you could then actually not even load the alternator while trying to extract max power from the engine. You'd use a clever charge controller between the 42V alt and the 42V battery that would allow charging on overrun and partial throttle, but reduce alternator current draw when above X% throttle opening, or some more sophisticated arrangement, if desired. Then you can still get the comp to run to produce the cools when you need it to cool your weary body (or the air charge) by leaning on the battery for part of the lap.
And so on, and so forth. There's a dozen things that you could come up with like that if you really wanted it.
On 31/05/2022 at 3:21 PM, GTSBoy said:
And....no. You're not going to draw 3ish kW of power from a 12V supply.
BEVs and hybrids that use electric AC compressors are running them on the 42V standard that sort became the thing when such high power demand applications started to become a thing, or even higher voltages. This because..... they have higher voltage available.
You wanna rig up a special alternator capable of putting out 42V, then yeah, maybe.
True, didn't think of the voltage they run at if using one direct from an EV. And the cost.
Not sure what the aftermarket is like for stuff like that, obviously electric water pumps and ps pumps are popular, but they have a demand among track and motorsport cars hence the options exist. AC pumps however, not so much
And they only draw 1 to 2 digits of Amps. AC compressors would draw 3 digits (at 12V).
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
