What aftermarket turbo are you running on your RB20DET
  • Replies 80
Im just wondering what aftermarket turbo are ppl on here running on there RB20DET and what sort of power are you making???
Shameless plug
Dont know exactly how much power it had as i never wound up boost and dyno'd it...but same turbo on RB25s make 250-270rwkws. So on an RB20 i would have thought 230-250rwkws would have been realistic
the TD06 uses a different manifold, with ext gate.
see Troy's link on post #2 for all the details.
it is a much different set up to the 2530. if you are chasing good power (over 240rwkw) go for the TD06
Well thats what im hoping but plenty of ppl are tellling me that due the valve size and std cams RB20s wont make good power once you start to venture over the 300rwhp figure????
If thats true then tha lesser response of the TD06 wont pay off up top :Oops: Just grabbed another std RB20 to get the thing back on the road (more money :) ). Should know Friday....but ive been saying that for a while now :rofl: the GTR cams i have are dead, might see if i can get another set somewhere but would rather some 256 8.5mm jobbies
HKS2530 is pretty much the sweet spot. Much more and it becomes a bit of a pain in the arse on the street. Unsure of the 2535 does on the rb20.
LOL...depends how you drive on the street. :P
Id actually say its easier/nicer to drive then a 230rwkws RB25 (ie torque monster) i drove recently as the thing isnt ramping hard onto boost all the time. When you want to GO its a concious decision as you have to wind 4000rpm into it then it takes off.
But i think a 2530 is the money...std injectors, std AFM and std ECU for a nice and reponsive 210-230rwkws...what more can you ask for?
Im mainly interested in drag racing, if i had a PowerFC, Bigger Injectors what would be the best turbo i should get that i can make at least 230-250 RWKW without tons of lag
I was thinking of the TD06 but i dunno if it would be my best option
as for the 2530 im thinking it would be good but weather it will be able to flow enough air for 240kw?????
2535 would flow enough easily i would think.. better off getting cams and gtr cam gears and have more midrange and top end.. with something like 1.3 bar.. 1.4bar i wouldnt be suprised if you could reach 250kw with this.. of course, coola, exhaust, injectors, computer as well tho..
anyone know if the 2535 is external w/gate or not and will it bolt up to the rb20 manifold?
I put the same post on skylinesdownunder.com and someone put up they are getting 294RWKW from a RB20 with a GT30 and 100 shot of NOS????
GTR cams i take it you just use the ones from a stock RB26DETT??
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
