VLRB20DET Posted August 8, 2004 Share Posted August 8, 2004 Im just wondering what aftermarket turbo are ppl on here running on there RB20DET and what sort of power are you making??? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/ Share on other sites More sharing options...
Roy Posted August 8, 2004 Share Posted August 8, 2004 Im just wondering what aftermarket turbo are ppl on here running on there RB20DET and what sort of power are you making??? Shameless plug Dont know exactly how much power it had as i never wound up boost and dyno'd it...but same turbo on RB25s make 250-270rwkws. So on an RB20 i would have thought 230-250rwkws would have been realistic Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-973203 Share on other sites More sharing options...
rb20-calais Posted August 9, 2004 Share Posted August 9, 2004 hks 2530 20rwkw 17psi blows some black smoke so i reckon there is more in it. evan Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-973672 Share on other sites More sharing options...
AzzurrA Posted August 9, 2004 Share Posted August 9, 2004 hrm, i'd hope that there's more in it if its only getting 20rwkw Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-973707 Share on other sites More sharing options...
rbs13 Posted August 9, 2004 Share Posted August 9, 2004 soon will be tdo6 20g 8cm exhaust housing int gate.. hoping for enough power to blaze stockies in 3rd all the way so maybe 25kw.. iv heard of 2530 run 20kw and he was doin well..so heres hoping Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-973972 Share on other sites More sharing options...
bbenny Posted August 9, 2004 Share Posted August 9, 2004 HKS 2530 230rwkw at 1.2bar wicked response too Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-974254 Share on other sites More sharing options...
VLRB20DET Posted August 9, 2004 Author Share Posted August 9, 2004 is the TD06- 20G a direct bolton to the standard exhaust manifold or it requires a custom manifold also is the TD06-20G a much larger unit than the 2530?? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-974469 Share on other sites More sharing options...
bbenny Posted August 9, 2004 Share Posted August 9, 2004 the TD06 uses a different manifold, with ext gate. see Troy's link on post #2 for all the details. it is a much different set up to the 2530. if you are chasing good power (over 240rwkw) go for the TD06 Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-974625 Share on other sites More sharing options...
Roy Posted August 9, 2004 Share Posted August 9, 2004 the TD06 uses a different manifold, with ext gate.see Troy's link on post #2 for all the details. it is a much different set up to the 2530. if you are chasing good power (over 240rwkw) go for the TD06 Well thats what im hoping but plenty of ppl are tellling me that due the valve size and std cams RB20s wont make good power once you start to venture over the 300rwhp figure???? If thats true then tha lesser response of the TD06 wont pay off up top :Oops: Just grabbed another std RB20 to get the thing back on the road (more money ). Should know Friday....but ive been saying that for a while now the GTR cams i have are dead, might see if i can get another set somewhere but would rather some 256 8.5mm jobbies Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-974648 Share on other sites More sharing options...
rbs13 Posted August 10, 2004 Share Posted August 10, 2004 you can purchase a t3 int gate tdo6 like i did.. bolt on with new oil lines/spacer and longer bolts.... thats al oh and new cooler piping and dump pipe.. Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-975681 Share on other sites More sharing options...
SXC180 Posted August 10, 2004 Share Posted August 10, 2004 T04e with external gate roughly 250rwkw Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-975804 Share on other sites More sharing options...
Cubes Posted August 10, 2004 Share Posted August 10, 2004 HKS2530 is pretty much the sweet spot. Much more and it becomes a bit of a pain in the arse on the street. Unsure of the 2535 does on the rb20. Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-975836 Share on other sites More sharing options...
Roy Posted August 10, 2004 Share Posted August 10, 2004 HKS2530 is pretty much the sweet spot. Much more and it becomes a bit of a pain in the arse on the street. Unsure of the 2535 does on the rb20. LOL...depends how you drive on the street. Id actually say its easier/nicer to drive then a 230rwkws RB25 (ie torque monster) i drove recently as the thing isnt ramping hard onto boost all the time. When you want to GO its a concious decision as you have to wind 4000rpm into it then it takes off. But i think a 2530 is the money...std injectors, std AFM and std ECU for a nice and reponsive 210-230rwkws...what more can you ask for? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-975854 Share on other sites More sharing options...
VLRB20DET Posted August 10, 2004 Author Share Posted August 10, 2004 Im mainly interested in drag racing, if i had a PowerFC, Bigger Injectors what would be the best turbo i should get that i can make at least 230-250 RWKW without tons of lag I was thinking of the TD06 but i dunno if it would be my best option as for the 2530 im thinking it would be good but weather it will be able to flow enough air for 240kw????? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-975950 Share on other sites More sharing options...
rbs13 Posted August 10, 2004 Share Posted August 10, 2004 2535 would flow enough easily i would think.. better off getting cams and gtr cam gears and have more midrange and top end.. with something like 1.3 bar.. 1.4bar i wouldnt be suprised if you could reach 250kw with this.. of course, coola, exhaust, injectors, computer as well tho.. Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-976045 Share on other sites More sharing options...
VLRB20DET Posted August 10, 2004 Author Share Posted August 10, 2004 anyone know if the 2535 is external w/gate or not and will it bolt up to the rb20 manifold? I put the same post on skylinesdownunder.com and someone put up they are getting 294RWKW from a RB20 with a GT30 and 100 shot of NOS???? GTR cams i take it you just use the ones from a stock RB26DETT?? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-976471 Share on other sites More sharing options...
yogi000 Posted August 10, 2004 Share Posted August 10, 2004 how do the HKS 2510 respond with rb20, i'm not looking for much hp just good response and mid range?? Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-976483 Share on other sites More sharing options...
Busky2k Posted August 11, 2004 Share Posted August 11, 2004 On a dyno day last year an R32 with an 2510 pulled 19xrwkw. Not bad, and probably could get more from it too. And it would be super responsive! Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-977035 Share on other sites More sharing options...
yogi000 Posted August 11, 2004 Share Posted August 11, 2004 thats impressive, only ask because u can get them from jap auctions for like 350 with only 5 -10000 on it....then shippin and what ever else i'd be saying 550-600 landed Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-977071 Share on other sites More sharing options...
Remix- Posted August 11, 2004 Share Posted August 11, 2004 Wow, you can hook up a 2510 for 600 landed? Show me where! Link to comment https://www.sau.com.au/forums/topic/48370-what-aftermarket-turbo-are-you-running-on-your-rb20det/#findComment-977174 Share on other sites More sharing options...
