  • Replies 80
2530 here. Making around the 200rwkw mark @ 1 bar.
Mods in my sig.
My brother put a T04 on his 32 and is running a powerfc. Over 300rwhp. But when i drove it i noticed that 1st doesn't really boost at all and 2nd isn't much better. 3rd gear hang on lol.
Scott
I'm lookin to update my turbo .. but i'm in two minds ..actually 3 minds on which one to select..
Help me out.
(sorry for hijacking thread a little)
HKS 2530
or
Garrett GT28R
or
Garrett GT RS (GT28RS) i think
i'm lookin to run 1.2bar ..and produce around 240rwkw
Are these capable of this? with injectors, ecu, fuel pump, cooler and cams?
thanks
Matt
mm2death- how hard does your r32 pull, what is your redline and when does boost come on? thanks in advance.
Yeah goes great. I've made a few people shit themselves...lol. But like with everything, you get used to it and then after no time at all you wanna go faster :D
Redline is about 8...not totally sure as i always shift at 7 the most. Boost hits fully at around 3500.
Cheers,
Scott
Hmmm, this thread is interesting
I have always thought my turbo was a HKS GT2510. Due to the CHRA tag being un-helpful (no numbers that meant much) I have always taken the sellers (JMS) and the installers ( Tilbrooks ) word for it. Also has a HKS 1bar acuator (although it only gets it to 0.9bar :) ) and also has a cast HKS dump pipe
It bolts on, and is definatley a HKS 25 series from the housings etc, but looking a MM2deaths post, how you say full boost is at 3500rpm, I am now thinking differant
Mine makes 200rwkw at 0.9 bar, and full boost is from about 4500-4800rpm and pulls really well from there to the rev limit at 8200 rpm (re-mapped chip)
Any idea's? I am now thinking 2530 or 2535 perhaps?
Chris
from what i know the gt rs is an update of the 2540, similar and made  more responsive providing an extra 30 odd hp than the 2540 also.
i thought it was more closely related to the 2835 turbos. power between 2835 and 2835R, with slightly better response.
Hi guys, for what it’s worth, our RB20DET has a GCG ball bearing hi flow of the RB25DET standard turbo, makes 1 bar at 3,100 rpm, some boost at ~2,500 rpm (depending on load), has GTR cams, adj camshaft pulleys, std R33 GTR intercooler, split dump, no cat, 3.25” exhaust, Power FC with boost control kit, well tuned (not by me), 225rwkw at 6,900 rpm using 1.3 bar, power flattens over that but doesn’t drop off dramatically, revs to 8,250 rpm easily (needs shift light, badly).
The result is the sum of the parts, not just one single part. That means you won’t get a similar result (whether it is good or bad) just by choosing a turbo.
Hope that helps
Chris
Does the front look like this?
Scott
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
