Hi guys, recently I suddenly lost almost all pressure in my clutch pedal, only the last few centimeters give any resistance. I'm still able to change gears and drive but the biting point is now at the very bottom whereas it used to be much more up top. I read some posts here and figured I probably have a leak somewhere. Got the car up on the lift and it seems like my slave cylinder might be leaking? The little boot is all sticky and when I pull the boot back quite some fluid spilled out, is this normal or does this indeed indicate that the slave is leaking?
Furthermore I noticed that the clutch booster (not the damper) is completely corroded from the bottom, so I'm assuming it's leaking as well? I've seen some delete kits and was wondering what you guys think of those? I don't mind a heavy clutch and I'm never going triple plate or something crazy like that anyway.
I've attached some pictures of the slave and the booster.
Any help much appreciated!
https://www.sau.com.au/forums/topic/483709-leaking-clutch-slave-cylinder/
I'd be very grateful that your car gave you notice regarding this issue, rather then leaving you stranded and needing a tow home.
I would replace the master cylinder, slave cylinder and use a braided line that deletes the damper. The stuff from GKtech work well.
You can bench bleed the complete system out of the car, then install it all together and do the final bleed once installed. Bench bleeding will get you 95% there and will make your life much easier.
I've deleted my clutch damper and noticed 0% change in the way the clutch performs or feels.
  • Like 1
Thanks for the quick response and the solid tip to bench bleed it!
About the damper, to avoid confusion, I believe you are talking about the clutch damper, the square box underneath the car, whereas I was asking about the clutch booster, which is behind the M/C mounted to the firewall. I will without a doubt get rid of the damper but deleting the booster seems to get mixed reactions on the forums.
Furthermore, a new booster appears to be around 400 AUD whereas a delete kit can be found for 100 AUD. This raises the question if the booster is really that needed.
You will be fine without the booster, it is one of those things that nissan over-engineered on the GTR.
Murray did mean that box and the looped clutch line, because again it is not required and does not improve things (in fact, it will make the new setup almost impossible to bleed as it traps air because it is horizontal not vertical).
The damage on your booster is due to the clutch master leaking brake fluid onto it, and it does look like the slave is also leaking. The booster damage is probably just cosmetic because if the booster was leaking you would notice poor/inconsistent clutch pedal feel and/or poor idle in the motor.
So, take the booster off, clean and paint it and reinstall, buy a new master and slave cylinder with a new braided line between the two and you will have another 30 years of trouble free clutching.
  • Like 1
Yes sorry, I was talking about the damper and not the booster. I've got a gtst and it doesn't have a booster so it didn't even come to mind when I was typing up my reply.
With the caveat that brake fluid leaking into the booster can damage the diaphragm. So when taking it off and cleaning it on the outside, do your best to work out what the situation is inside, and deal with any fluid in there appropriately.
  • 4 weeks later...
No clutch leave you stranded? It's definitely a pity to drive but any manual car can be started and shifted through all gears without a clutch.
In my youth, I had a buddy run an 88 civic without a clutch pedal for 6 months before he could afford a new clutch cable lol. Why buy a clutch cable when you could buy smokes and beer... priorities when young and stupid lol.
Edited by TurboTapin
Yep, master cylinder failed about 10km from home. So it was a cheap and quick tow home.
I'm becoming an old man, I'd rather just get it towed then stuff about trying to drive it without a clutch lol.
On 04/06/2022 at 8:23 PM, Meap said:
Thanks for all the replies guys! I bought a new master and slave, braided line and the booster delete by PRP. I'll keep you guys posted!
Instead of a new master you know a genuine RB26 clutch master cylinder rebuild kit is like $50 right ? 99% fixes an issue unless the inner bore is scored to shit. Generally just the plunger seal lets go.
NOBODY ever seems to listen when i talk about rebuilding hydraulic components.....so good luck with this advice Ben.
  • Haha 1
To be fair, I went looking for a rebuild kit for the RB25 clutch master cylinder... Couldn't find anyone that had one.
So I just grabbed a new one from GKtech for $86 and figured no one sells rebuild kits for them when you can buy an entire new one for such a low price.
https://au.gktech.com/products/gearbox-clutch-components/clutch-masters/hfm-clutch-master-cylinder-s14-s15-r33
Edited by Murray_Calavera
  • 9 months later...
Just to close this topic off and help people that might have the same issue I did, after replacing the aforementioned parts, all problems were resolved (as expected).
Some notes I want to add;
1) I don't notice any significant change in pedal feel after removing both the clutch damper (square box) and the clutch booster
2) I didn't bench bleed the system before installing it and despite my strong simplification of the system it was still a PITA to get all the air out, so for anyone looking to do the same as me, please bench bleed it first
  • Like 1
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
