I'm in the process of swapping out my OEM turbos for GT2859s
There are a bunch of M12 & M14 & M18 copper washers for the oil and water lines.
Can anyone tell me the correct/OEM thickness for these?
The washers I have removed are 1mm thick and I assume that is more or less the same before they were originally tightened i.e. the crush is negligible.
The replacements I have are 1.3mm thick.
Not sure if the loss of bolt thread contact is an issue or not, especially for the banjo bolts that attach directly to the turbos.
I'm tempted to anneal the original washers but for some reason that doesn't feel right.
I'm probably over thinking but would value anyone's thoughts.
Would also like to understand why Nissan used two washers connected together for the Turbo oil inlet.
Thanks
Lee
https://www.sau.com.au/forums/topic/483710-turbo-copper-washers/
First up, Nissan didn't use 2 washers on the oil inlet which is the clue that it has all been apart previously and you may not be looking at factory washers anyway.
To work out if your 1.3mm washers are OK (I guess so), measure 2 washers + the banjo and subtract the length of the banjo bolt under the head to the end of the thread. As long the answer (ie, how far the bolt will go into the housing) is at least the same as the diameter of the bolt you are all good, probably even a little less is OK as these are hollow bolts anyway.
Thanks
Lee
https://nissan.epc-data.com/skyline/bnr34/3957-rb26dett/engine/144/15188A/
Looking at the diagrams I don't see double washers. That sounds like an oil leak waiting to happen. The only exception is certain cases where there is a lock washer (split ring) and a flat washer.
So the two connected washers I'm talking about are labelled 15192F in the 3rd diagram on the page linked to in the response above. The OEM part number is 1518913C00. The two washers sit either side of a banjo but are connected by a strip of copper. As I said above this is for the oil inlet banjo bolt attached directly to the turbo (i.e the where a HKS 0.8mm restrictor bolt would go if needed) not the water/oil tube adapter that bolts to the turbo.
I've measured the amount of thread that will go into the housing and it is 5mm with the 1mm thick OEM washers and only 4.4mm with the new washers. The banjo bolt is M12 - hence my concern.
I've attached a photo to help explain the above showing the OEM washer and the thread depth with the new washers.
Love this forum. As someone who has zero access to GTR expertise and no mechanical background I find the posts here invaluable - thanks.
Lee
The thickness difference you mention is negligible. As was said above, the connecting part is for ease of installation rather than needing to hold the inside washer in place while trying to line it up. New pipes with already attached banjo bolts sometimes have a plastic retainer that you rip off once you get the threads started.
They're not that specific, just make sure they're thick enough to actually be crushed and not too thick that it reduces the thread engagement - both unlikely. So just get your diameters right and tighten it up.
Oh and copper washers should not be doubled up.
  • Like 1
Lee
Just to add, that does not look like the correct banjo bolt. Not a washer issue, that bolt looks too short
  • Like 1
Thanks for all the replies - very useful.
That's definitely the correct banjo bolt. I've attached a picture of mine and the bolt indicated from the parts page linked to above.
It seems to me to have very little thread engagement but I assume Nissan know what they are doing and it hasn't leaked in the 22 years I have owned the car 🙂
A reduction of 0.6mm (2 x washers x 0.3mm) may not be significant for most bolts but I'm concerned that it is a relatively large amount for a bolt with such little thread engagement.
I'm leaning towards trying to source some 1mm thick washers or annealing the originals but would really appreciate any other comments.
Have you considered buying the OEM part? Seems to be pretty cheap.
"Seems to be pretty cheap."
Not where I'm based it's not especially when postage is thrown in. The M12 x 18 x 1mm spec washers are pretty rare here - they all tend to be 1.5mm or rubbish quality. Its seems though that that spec is used by some of the motorcycle manufacturers as OEM equipment and I have found a supplier so it looks like that's how I will proceed.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
