Hi all,
Seeing as I don't use the stock dash, I popped a coolant pressure sensor in the stock dash temp sensor location. Set it up in the Haltech and the pressure reading looked good.
Had a track event today, half way through the day and engine protection started kicking in - 0 coolant pressure.
Before I start digging deeper, I just wanted to make sure I haven't picked a stupid coolant pressure sensor location. I thought I could essentially mount it anywhere, but maybe the sensor is up too high? I'm not sure why it read fine to start but now reads 0 psi.
Probably worth mentioning, there were no issues with the coolant overheating and temps were consistent with what I would expect on track.
https://www.sau.com.au/forums/topic/483722-coolant-pressure-sensor-location/
It's frustrating as its a $250 sensor from Haltech :( I've also used one of those sensors for fuel pressure, and they read low when running e85. I'm guessing there must be a rubber o-ring inside the sensor that is effected by the ethanol. I think Haltech should drop these range of sensors, especially as they sell stainless ones for the same price =/
Are these the Bosch sensors you were thinking of?
https://www.efisolutions.com.au/bosch-fluid-pressure-sensor-10bar-145psi
Any thoughts on sensors like this? (it would be easier to keep things 1/8 NPT)
https://www.efisolutions.com.au/stainless-steel-pressure-sensor-150psi-1-8-npt-thr~127222
Yep that's the Bosch sensors I will move to once my Halaltech one dies. Just one thing, I've been told the Bosch sensors do degrade then eventually leak fluid out of the connector (can't win it seems).
I'm running 2x of those EFI Solutions sensors on the car at the moment too. Was being tight and didn't want to buy a Haltech one lol... 1x is being used for EMAP and 1x is being used for Oil Pressure.
The first sensor is the new metric thread and I use them with no issues.
Second one is probably a copy of the original bosch but 1/8 thread as what everyone use to use.
I haven't had an issue with the Bosch sensors in 7 years even mounted on the block for oil pressure.
  • Like 2
Yeah if I was doing everything again from the beginning, it would be great for things like oil pressure/temp. But in this case the factory water temp sensor is working fine so there isn't really much driving me to use the combined temp/pressure sensor.
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
