- Do most modern aftermarket head units come with ISO male connectors at the back?
- So, when fitting a modern head unit to a modern car you typically need a single harness adapter, eg nissan to ISO female
- When fitting an older head unit you'd typically need two harness adapters, eg a nissan to iso female, then iso male to pioneer/JVC/whatever
- Are all the <$300 no brand Android head units dogshit?
tnx
https://www.sau.com.au/forums/topic/483725-noob-questions-iso-connectors/
tnx
No idea on the connector side
All the cheap ones are rubbish, not enough ram and slow to start and load apps. Also found the supplied mics to be not  good on sound pick up.
  • Like 1
  • 4 weeks later...
To answer my own questions;
- (Some/all) head units don't come with ISO connectors so (some/most/all) connections are via two harness adapters, eg a nissan to iso female, then iso male to pioneer/JVC/whatever.
- I also needed a 'Nissan Double Diversity' aerial adapter (Aerpro AP348A). IIRC the R32 skyline had the same aerial connector as the Stagea.
So for the Stag to JVC, i got;
- 'Nissan ISO Connector' APP0120
- 'JVC to ISO Harness 16 pin' APP8JVCS
- Nissan Double Diversity' AP348A
It worked once then nothing. Suspect there is an underlying wiring issue that was present before the change as i had issues with the factory system.
  • Like 4
Had a similar issue when I upgraded the stereo in the m35 I used to have. From memory I ran a grounding wire screwed into the frame of the head unit and chassis. Didn't make sense to me but it made it work and I never had the issue again. Give it a go, can't hurt anything.
  • Like 1
Ok, so the 15amp 'radio' fuse near the battery had blown. Replaced it and the new radio works again. However, it appears that the climate controls are dependent on the factory radio being plugged in.
admS15s post above made me think that maybe the ac controls are getting earth from via the oem radio connector, so i tried earthing its chassis but it didn't seem to help.
So my next guess is it needs the BAT and IGN +12v?
Anyone know if the climate controls require the oen radio plugged in/what the dependency is?
Found this;
"I'm about to order a single din ac control board from the states. This is what you need if you're getting rid of your pos bose integrated stereo (or the non bose integrated). You need this board because the ac controls are all part of the clarion (bose) circuit board and when you remove the stereo you remove the ac controls."
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
