Has anybody successfully worked out how to have an aftermarket gear position indicator for an auto in a stagea?
With the Link dash installation almost complete were having issues getting the gear position to show on dash unit, as the factory dash uses 2 seperate signal types between the box and the ECU, as in it receives a square wave signal and transmits a sine wave or vice versa, so it's not reading and allowing the dash panel to show .
It will also be making it potentially worse being that the trans is a manualised valve body and being Jatco 4th gear is electrically selected as well as the lock-up for converter, so they are switched seperate
https://www.sau.com.au/forums/topic/483731-gear-indicator-display/
On 6/6/2022 at 8:05 PM, GTSBoy said:
Just do it calculated off of vehicle speed vs RPM.
We can potentially do that, but what about indication for neutral, reverse,park and converter lock up? And would also like to avoid any more thousands in labour costs for calculating and calibration, am reaching out to Link and Aim(dash manufacturers) to see if they have a work around,but thought there may have been someone that's seen it done in a track,drift or drag car that has a Jatco box???
I can look into the wiring tomorrow and see where it picks up the signal if you want
  • Thanks 1
There are switches for those, no?
TC lockup could possibly be inferred from rpm vs speed also. If it sits dead bang on the relationship given by the gearing, then TC is locked up. If it is in the "band" available from TC slip around the gear ratio, then it is unlocked.
Yep there are 2 manual switches for 4th gear and lock up, so they're the easiest to solve I spose in comparison, just a bugger that the Link ecu and the Link dash can't bloody read the gear position by themselves, and seems that I'm always the damn guinea pig too, but that's my fault for wanting pretty /shiny things and jumping first....
I have replied in other thread, this is so easy to do and isn't thousands to setup by a competent workshop/tuner.
Its all in what is wired to ecu and in its setup so many people have no idea how to do it right.
Can't you snoop the TC lockup solenoid to determine this too?
Honestly have no idea with anything that has wires cos I tend to let the smoke out of them, so I leave that stuff to others and stick to mechanical things that I can see what they do and how.....
The 2 shift solenoids form a 2-bit number which describe the forward gears. But don't assume, 0 is first first gear, and 3 is 4th gear. I think from memory b00 is actually 3rd.  The ECU loom also has wires which are digital states for when central shifter is in reverse, neutral or the forward gears.
Coupled with some microcontroller logic (or lucky you if your ECU is modern and has some flexible inbuilt programmable logic), you could determine what gear is currently active, and drive an LED digit display.
Forget the speed vs rpm method for an auto.
P.S.
From one of my micro programs the solenoid combos are as follow (LSB being solenoid 1)
b00 : 3rd gear
b10 : 2nd
b01 : 4th
b11 : 1st
P.S.
b00 : 3rd gear
b10 : 2nd
b01 : 4th
b11 : 1st
Cheers, will look into this
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
