Currently i need to plug my phone in with a cable to play music in my Stag, and i want to change to bluetooth and keep the center console volume button working as it does now.
An aftermarket head unit had been installed in the passenger side slot where the navigation system usually lives, and the navigation system was retained but moved underneath. The aftermarket head unit daisy chains with the factory system such that when TV is selected on the center console, i can play music from my phone via cable. The audio appears to work by connections run from the head unit to the factory TV box at the rear of the car. Makes sense that the audio works when TV is selected.
Question - is there any weird dependencies that will mean i can't take the Nav unit and TV unit out of the system? I'm hoping i can just splice the audio out from the new headunit into the audio out from the TV box.
https://www.sau.com.au/forums/topic/483751-m35-audio-change/
I'd focus on getting the new aftermarket wired into the speakers directly rather than routing through the factory tuner.
If it's the integrated model, I have seen guides on bypassing or powering the factory Bose amp otherwise just run new speakers into the doors (bonus being you've got new wiring if you want to upgrade the system with a decent amp down the track).
If you're ripping the screen and buttons out, I may be interested in buying it from you.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
