BRAND NEW IN BOX. NEVER OPENED.
CUSCO PILLOW BALL TENSION ROD FOR BNR32
CUSCO 231 473 ASN
Adjustable Tension Rods for BNR32.
https://www.carmodsaustralia.com.au/adjustable-pillow-ball-tension-rod-r32-gtr
Brand
CUSCO
Product Number
231 473 ASN
Compatible Car
NISSAN Skyline BNR32
Compatible Engine
4WD
Product Description
Year: 1989.8 - 1993.8
type: Adjustable with Pillow Ball Mounts
adjustment range: +5 to -9 mm
Material: Steel
Price: $250, pick up from Gladesville area, NSW.
Edited by niZmO_Man
multiple threads merged
https://www.sau.com.au/forums/topic/483752-parts-for-bnr32/
Item: GReddy Oil Cooler & Filter Relocation Kit Skyline BNR32
Part No: NS1010G
https://www.trust-power.com/products/cooling-parts/oil_cooler_kit
Condition: Brand New In Box.
Price: $1000.00 $800.00
To Fit: BNR32
Comments: "GReddy/GREX Oil Cooler Kits help prolong the life of your oil and in turn your internal engine components. Hard driving causes higher engine temperatures. GReddy/GREX oil coolers are an excellent addition, and are especially effective in harsh driving environments. By using a similar inner-fin core design as our famous intercoolers, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life. Our systems also offer an internal (or external) thermostat (opening range 71-85 C) to allow for quick engine warm up. The efficient core and durable steel-braided lines ensure good flow and a leak free installation."
In addition, all kit have fittings for aftermarket oil pressure and temperature meters.
BNR32 Skyline RB26DETT (mounts in front of radiator) (core type NS1010G, 10 cooling rows #10 fitting)
group-641bead5-c227-4152-b9e1-012077ef8c2b-420_accf58a1-f3b4-4175-b7cc-5d6795f1e1e9_420x420.webp
https://www.sau.com.au/forums/topic/483752-parts-for-bnr32/#findComment-7966568
Item: Cusco Oil Catch Can for BNR32
Part No: 231 011 A
Price: $100.00
To Fit: BNR32
https://www.sau.com.au/forums/topic/483752-parts-for-bnr32/#findComment-7966569
  • niZmO_Man changed the title to Parts for BNR32
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
