I’m look to run a set of the new garret g25-550s on my rb26/30. Aiming for a vicious 30dett
Will have to find the cam card but from memory. the head has a set of kelford cams 10.8mm lift and 280 degree duration
the block is forged and balanced
engine is going into a street GTR
Yes I could go single but just want something different
What you all think will the 3l have enough puff
aiming for 700+
https://www.sau.com.au/forums/topic/483756-rb30dett-garret-25-550/
Assuming HP at the wheels, then you might struggle to make it. I don't have any direct experience on this sort of setup, but just looking at the compressor map, and thinking of a single one of these on a 1.5L engine needing a lot of boost to make 475-500 engine HP, then there's a bit of a conflict between the likely 2+ bar of boost required to make that sort of power and the need for the compressor to be flowing 45-50 lbs/min of air. You'll be right over on the RHS of the map, over near the choke region, pulling middling efficiency and running close to max shaft speed.
But, if I had to guess, I'd say it would be a ripper and do pretty much what you're asking for.
Hi there thanks for the above.
what attracted me to the 550’s is the new technology but to be honest I wouldn’t have a clue possibly there’s better suited turbs
dyno Will be hub type in NZ lol
my friend is running /5’s on a rb26 on pump gas making 430kw (hub dyno) - so with my situation 3l block and slightly bigger turbs on E85 we should be able to hit 500kw mark with out to much effort
 I recon the correct comb is out there there’s no info around as everyone goes single
So do you think I’ll need 30lb plus boost to hit target? is it possible to change rear housing.
(ripper) yea bro I’m excited
  • 1 month later...
Look at the motive GR Yaris build. I think 700 at wheels will be easy. If you can make 400 at wheels on 98 and 500 at wheels on e85 from a 1.6L 3cyl. I was thinking about a similar setup with my build. But G series were very new back then and there was almost no data on them. There is an R34 time attack gtr that runs twin G25s. There is a very good YouTube video about it. Good luck. Would love to see how you get on
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
