Yes, it's time for another SAU NSW Sunday Session! Time flies when you're having fun, I guess??
As each month passes, we get to see more and more of you at each Sunday Session, and we couldn't be happier!
Once again, we're changing up the formula by having this event at yet another location! Not only that, but we're going to have a cruise with this one too!
So now that your taste buds are tingling with excitement once again, make sure you save these details to avoid missing out:
Date: Sunday 14th August 2022
Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map)
Meet Time: Meet at 8:30am for a 9:00am departure
Destination: Eat Street Gosford
Map: https://www.google.com.au/maps/dir/Cowan+Rest+Area+-+Truck+Stop,+Cowan+NSW+2081/Eat+Street+Cafe,+Masons+Parade,+Gosford+NSW/@-33.5997716,151.1860076,12.58z/data=!4m34!4m33!1m25!1m1!1s0x6b0d50be6b302f7b:0x52a920c40b292919!2m2!1d151.1590249!2d-33.6114826!3m4!1m2!1d151.1628302!2d-33.6052549!3s0x6b0d509345312641:0xb510e358747a5332!3m4!1m2!1d151.2008102!2d-33.5270314!3s0x6b0d4e5add310b35:0x7ba39fa9e741619c!3m4!1m2!1d151.1926785!2d-33.459769!3s0x6b0d4923ff110087:0xdf075a624d2eccfc!3m4!1m2!1d151.2315682!2d-33.4306378!3s0x6b0d4989ae5589b1:0x36edb8bf8e7bef35!1m5!1m1!1s0x6b72b559059a8d11:0xcdde3a977bf88712!2m2!1d151.3419392!2d-33.433604!3e0
Itinerary:
First up, we'll meet at Cowan Truck Stop and jump straight onto Old Pacific Highway!
This is the same run as our Old Pac Highway run, except that our final will be at Eat Street in Gosford.
Please be mindful of the added police presence lately so best behaviour is expected!
There will be a lead and follow car so no one should get lost.
We will also be bringing along walkie talkies to keep the group together so if you have one please bring it along.
If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior!
This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days.
This is an official SAU:NSW event and will be run under a Motorsports Australia permit.
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
• Be aware of surrounding environment and act accordingly.
• Drive courteously on the state’s roads as a true enthusiast should.
• Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly.
• Any misbehaviour will not be tolerated and you will be asked to leave.
Thanks guys and hope to see you there!
  • Like 1
  • 1 month later...
  On 13/08/2022 at 6:50 AM, soviet_merlin said:
Meh, not going to make it after all. Hmpf. :( Aiming for the Bathurst cruise now in two weeks.
Expand
DAVE!!!! I was wondering where you and Jen were today!!!!! Guess I should have checked here earlier... LOL!!
You definitely better make it to the Bathurst run!!!
Expand
Man, tell me about it! We were looking forward to it for weeks. Are you going to upload photos?
I was a bit worried about the wagon on Sunday. There's a tear on one of the driveshaft boots. It had been puking grease everywhere. Thought it might be better to not boost it through the twisties. I now learned it is not that big a deal and it looks worse than it is. Anyways, will get it sorted next week.
So yeah, very much looking forward to Bathurst now!
Expand
Yeh man... I'll definitely be posting photos! I'm still editing though, because work has been chewing a bit of my time haha!
Fair enough though... I probably would have done the same, so no sweat! :) But yes!!!! Make sure you get to the Bathurst run! I'm expecting a huge turnout! 😁
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
