  • Replies 47
Never heard of this company Grex, and it seems to me that 2.7 is done more by bore than stroke (cant rember stock rb26 bore).
From a recent discussion on another forum i understood that a 2.7 wont give that much extra power really, but if you are doing it to keep safe then it would be good.
but grex..... hope they are not releates to MotoRex in the usa
That price is just for the pistons, doesnt include the conrods or crankshaft that come in the higher priced ($10,000+) kits.
And yes, Grex is Greddy is Trust etc. They are the same company, but technically they are different.
is it worth the price tag
http://turbulence.com.au/shop/product_info...products_id=135
i thoguht they would be more expensive then that, can anyone confirm if the kit is any good
MrChams is running the Trust 2.7 kit in his R32
I sure am... there are different kits from what I understand.
The kit that I have is 87.5mm GREX pistons and GREX H pattern rods.
The larger 2.7ltr piston kit helps my Greddy T78 spool up quicker.
Due to the cost of after market cranks, I am running a standard crank that has been shot penned and cryogenically treated (dunno what the hell that is but hey...)
The standard cranks are pretty strong. Before my rebuild this crank held 720hp with no signs of breaking. Not sure what there limit is.
I'm still running in the engine. Once I have it tuned I'll let you all know how I went for power.
The kit on the link above is just the over sized 87mm piston kit.
This is not the stroker kit.
The piston size makes it 2.7ltr.
My pistons are 87.5mm not 86.5mm. Typo
If you check out this link, you can calculate the displacement
http://www.benedict.esu7.org/sblock/ccfrm.html
It's something like this (don't quote me on it)
Bore radius squared x pi x stroke x no. of cyl = Total cubic displacement
How do you get the extra stroke necessary for 2.7L from a standard crank and 86.5mm pistons? :confused:
how much difference? Just outta interest.
And running in an engine? Thats over-rated in this day and age
Ahhh okay...
Std bore & stroke (86x73.7) = 2568cc (juuuuuust enough to claim 2.6 Litres :P)
87.5mm bore & std stroke = 2659cc (also juuuuuuuuuuust enough to claim 2.7 Litres :))
Did you do these internal upgrades by themselves? Could you really tell the effects of extra 100cc capacity? Or did you do other things like camshafts, cam gears, etc etc at the same time?
The stoke on the trust piston is 75.7mm and the piston size is 87.5.
Regarding the mods etc,
It's not just the pistons that has given the improvement but extensive head work.
The head work included modifying the bowl shape, different angles on the valves and valve chamber, valve guide modified, cam area opened for bigger cams and the obvious port enlargement.
I am currently running the standard cams with adjustable cam gears.
Bigger cams will be fitted soon once I decide what size to get.
Yes, I did notice the difference. The engine does feel like it has more down low torque but I can't say till we tune it on the dyno.
Ahhh okay...
I don't agree with not running in an engine.
My mechanic use to work for Nissan Japan.
They did test on how to run in RB engines. He told me that the best result was when they ran the engine up to 4,000rpm for the 1st 1,500km then oil change then up to 5,000rpm to 5,000km.
He told me the bore was perfect after such a run in.
The test also involved using mineral based oil in some engines and full-synthetic in other engines.
The full-synthetic oil run engines came out much better.
The price is very high just for Greddy pistons.
You should be able to get the pistons for approx $2500 and the rods for approx the same, $2500...
damn, when i saw the pic and the price i already got the credit card out, but for pistons only hm doesnt seem worth it,
How exactly do you increase stroke by 2mm with a piston upgrade on standard crank? :confused:
And I don't need a web calculator, I remember my Year 7 volumetric formulas :Oops: Probably the first time I've used them since high school :)
5000km run-in??? That would take most people 6 months to complete. You really think that's a feasible run-in time?
What engine parts could POSSIBLY need 5000kms bedding in time??? :uhh:
No comment on the full-synthetic running in oil use... People have different ideas on that one, but the vast majority believe that mineral oil for the first 1000kms or so is still the best way to go.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
