Hey,
I'm having some starting issues with my rb25det neo. Its in a pretty much stock R34 GTT with an Elite 2000. It will just crank and not start, but sometimes will fire right up. I'm wondering if its my CAS that is the issue, but once it does start, it seems to run great.
It started this year after the Haltech install. Never had an issue before, and it worked perfectly for a week after installing the haltech too. The first time it happened, I could smell unburnt fuel, so I pulled the fuel pump fuse and it started up, so I thought it was just flooded. Now that doesn't work.
I put the timing light on it again, and the crank timing marks were nowhere to be found. Took the cas off thinking the key snapped, but it was fine. Put it back on and it started, and I checked the timing again and it was lined back up. Its almost like the ecu was seeing the timing 180 degrees out somehow. This has happened multiple times now, including this morning.
Some things I've tried:
  • I've taken out each coilpack and I get spark from all of them while turning my cas, and I hear the injectors clicking too.
  • I've synched my timing with the ecu each time.
  • I've cleaned the cas with sensor cleaner.
  • I've logged the ecu while cranking and it's getting signal from the cas.
  • I've looked over some wiring and can't see frays or anything.
  • Double checked my trigger settings, and they are the same as the original base map
I'm nervous to drive around now as it seems to be random when it wants to start. And it seems strange that once it actually starts, it runs great. Any ideas? I don't know anyone with a confirmed working cas otherwise I'd try swapping to see it it helped.
What is the condition of your battery as voltage may be dropping below arming/trigger setting. Adjust them if need be.
Check that and if not the problem invest in a NZwiring trigger kit. Super easy to install and setup too.
https://www.nzwiring.com/index.php/product/trigger-kit/
  • Like 2
Hey thanks for the reply. Yep I've been looking at some trigger kits so I might just have to take the plunge and buy one.
The battery seems to be good, and I've also tried starting while being jumped by another running car, with no luck. I will see if I can find the those voltage settings in the ECU and give it a go.
Update on this:
I got the car sketchily started and made it home now. I had to add 40 degrees to the TDC Angle setting in the Haltech and then it barely started but idled like crap. Put the timing light on it and sure enough the timing was out by about the 40 degrees. I put the same number I had before back in, 115, and its back to proper timing and idled fine.
Somethings off when its cranking it seems. I'm planning on just buying the trigger kit now
On 6/21/2022 at 9:09 AM, tylink720 said:
Update on this:
Scope the signal the ECU sees during cranking. This sounds like it could be a signal integrity issue.
I will try this as well thanks. I've ordered up the NZ Wiring kit so hopefully that will be here soon too
  • Like 1
Another update for this. I put the NZ Wiring trigger kit on and it was doing the same thing. Scoped the signals and was getting perfect readings off of it.
Ended up going through all of my fuses again and found one had blown, one of these ENG CONT fuses.image.thumb.png.3115d0907a47a0d115022a1c07edca46.png
Replaced it and the last 3 starts have been flawless. I'm hoping that this is finally the fix for it!
Side note, what do these 2 fuses actually do? I'm wondering how the car was even able to run if it was blown?
Yes, but the weird thing is, a standard 33 gtst runs fine with that fuse blown, while at least some aftermarket ECUs need it (it was actually absent from factory in S2 which is even weirder.) I've never traced the wiring for it though
  • Like 1
  • 3 weeks later...
The starting issue seems to be fixed due to replacing that fuse. I also emailed NZ Wiring and he gave me some tips and I have the car working very well now. Had to lower my trigger arming voltages a lot compared to the numbers in the install instructions. Thanks for the help!
I do get a trigger error once every couple of drives. It seems to happen when I press in the clutch during a lower rpm decel, or when letting out the clutch at a low rpms. It will happen once, then wont come up again for the rest of the drive or even multiple drives after. Strange
Edited by tylink720
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
