S
Hi all, so I have a problem with My RB26.
Sometimes upon startup a tick noise is intermittent or continuous. This noise slowly goes away. And yet sometimes like today, after fresh oil and filter, primed with cam trigger disconnected blah blah, started ran so quiet for roughly 10 mins, then tune changes to ghost cam idle once warm, the tick came back instantly as soon as the idle changed.
Stock head, stock oil pump, tomei Hg,tomei head studs, oil restrictors, still twins. 90k km engine. Runs 5w50 or 10w50.
Pulled oil filter apart to inspect. Nothing clean as a whistle.
Comp is all 155 160 across the board wet.
Can anyone shed some light? Got me stumped.
I have videos of it Running on start-up, then once the noise came. Wish I had video running when it happened.
Cheers 🍻
https://www.sau.com.au/forums/topic/483793-rb26dett-tick-noise/
narrows it down a bit.....timing cover (maybe foreign object or something broken off and bouncing around) or cam covers (nasty, could be a cam oiling issue)? Cam covers are pretty easy to take off and have a look for anything amiss.
Injectors are often noisey but you should be able to isolate that (and they should not get noisey then quiet.
Well, ticking lifters is usually just a (lot of work) clean, soak in oil, reassemble, or at worst, replacement, exercise. But solid lifters can only grab in he bucket bores if something has been damaged. Scuffed, squeezed, broken fragments of something else stuck somewhere, etc etc.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
    • Oof. Could be worse I guess. I suppose they haven't put any effort into ally suspension parts or CF panels, seats, etc. So they could probably pull about half of that back out of the car. Not like a bunch of other EVs that already have CF everything and roll the scales at ~2t.
