R33 power locks and windows stopped working
On 6/25/2022 at 11:39 PM, dee242 said:
i have already checked the fuses wiring and relays
I'm wiling to bet that this is not sufficiently true, otherwise you'd likely have found the problem, or at least narrowed it down.
So, when you say you've checked, what does that mean?
And, if there is power and earth where there is supposed to be at the door switches and control  modules, then......likely that the problem is inside a door control module. They do die. They have electronics inside them that don't last forever.
  • 3 weeks later...
On 13/7/2022 at 2:36 AM, Duncan said:
p15 of the link you posted says the door control module is B-77
p11 shows B-77 is connector 38, which is to the left of the fuse box under the driver's side dash
  • 1 month later...
I’m getting one volt to drivers door harness didn’t see any breaks in door joint fuse is not blown because electric mirrors n speakers still work replaced the door lock module no change only other thing I can think of is rcl module
  • 1 month later...
  • 1 month later...
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
