timing depending on the type of ECU can advance from 15 degs base to about 35-50 on high load. since your ecu has been chipped... depending on who chipped it may be more
removing the CAS and getting one tooth out can make a lot of difference. if you take the CAS off and then rotate the teeth, when you put it back on the adjustment can be so far out that standard adjustment point will not get it back down to 15 degrees base @ 800rpm on a warm engine. you'll have to remove the CAS rotate a tooth backwards, put it back on and then measure the timing again and see if you can adjust it then to get 15 degrees
scott , if you didnt have the engine on tdc on the compression stroke when you fitted the new timing belt , how did you do it then ? did you just put it anywhere ? you must have been lucky if you did that cause you could have bent some valves if it was out alot .
what you have to do then is put engine on TDC on the compression stroke .
this is how you do it : take out timing belt covers , crank pulley must be lining up with mark ( 12 o'clock ) both cam pullies must be lining up with their marks on the backing plates now install the timing belt , make sure all marks ( white lines usualy depending on what brand of belt you are using )on the belt line up with the marks on the pullies when thats done you have to make sure again that pullies line up with their marks . now you have to adjust the tensioner , this is how you do it : turn the crank clockwise twice with the bolt loose now put an allen key in the hole and while holding it tighten the tensioner bolt 43-58 nm do not overtighten or it may break and dont leave loose either . just check with your hand to make sure the belt is tight .
if i remember right the cas has a slot so you cant put it in wrong but you can turn it left and right when its installed so your timing will be right .
try all that and if you have probs let me know .
Thanks wrxhoon.
I did all of that last night. If only i knew the correct procedure the first time around. I aligned the crack pulley's yellow mark with the mark on the lower timing belt cover, and then aligned the dimples on the cam gears with the marks on the backing plate. Then put the belt on using the marks on it as a guide to line up to.
I didn't set it up on TDC last time. I just left everything in the same position from when i last drove it and put the belt on in the exact same place...well that's what i tried to do. My dad helped me do the job but seeing he is a V8 man, all this overhead cam 'stuff' is new to him...lol
Regards,
Scott
is it all done now ? you are very lucky you didnt bent any valves ! is it all back together now ? if you havent got the covers back on turn the engine clockwise a few times and check again all your marks when it comes to tdc and finaky check the tension on the timing belt when all done put together and check timing with timing light .
next time you take the cas out matk its position with paint or something and put together in the same spot so it starts easy and then check with timing light .
Thanks wrxhoon.
Regards,
Scott
wrxhoon,
I have all the covers back on. Should i take the top one off again and turn the engine over to check?
All i have to do now is put all the belts back on and put the radiator back in. Then i will check the timing with the light.
Thanks for the help.
Scott
tdc no 1 is when the crank pulley mark lines up ( 12 o'clock ) and at the same time the 2 cam pullies line up with their marks . if they all line up and the belt tension is right then its all good . did you do the tensioner bolt with a torque rench ? if you dont do it tight enough it will come loose to tight and it will break .
Yep all good now wrxhoon.
Timing is now at 17deg, which is a little more retarded than with the old belt on (I marked the CAS before i took it apart).
Thanks for all the help i really appreciate it. I learnt alot about my car in the process. :(
I will take it for a drive tomorrow and see how she goes.
Regards,
Scott
if you want to set it on 15 all you have to do is turn the cas a little like 1/2 a mm it will move it a couple of degrees .make sure you tighten the 2 bolts so it doesn't move . personaly i would leave it at 17 if it doesn't ping , its got to be 15 @ 650 rpm ( thats the specs )
It says under the bonnet 15deg BTDC @850rpm. I thought it was 650 as well...hrmm
Yeah when i put the CAS back on i set it to roughly the middle and when i started the car and let it warm up it came down to 20deg, so i had to adjust the CAS a little. I'll see how she drives today. :)
Cheers,
Scott
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
