timing depending on the type of ECU can advance from 15 degs base to about 35-50 on high load. since your ecu has been chipped... depending on who chipped it may be more
removing the CAS and getting one tooth out can make a lot of difference. if you take the CAS off and then rotate the teeth, when you put it back on the adjustment can be so far out that standard adjustment point will not get it back down to 15 degrees base @ 800rpm on a warm engine. you'll have to remove the CAS rotate a tooth backwards, put it back on and then measure the timing again and see if you can adjust it then to get 15 degrees
scott , if you didnt have the engine on tdc on the compression stroke when you fitted the new timing belt , how did you do it then ? did you just put it anywhere ? you must have been lucky if you did that cause you could have bent some valves if it was out alot .
what you have to do then is put engine on TDC on the compression stroke .
this is how you do it : take out timing belt covers , crank pulley must be lining up with mark ( 12 o'clock ) both cam pullies must be lining up with their marks on the backing plates now install the timing belt , make sure all marks ( white lines usualy depending on what brand of belt you are using )on the belt line up with the marks on the pullies when thats done you have to make sure again that pullies line up with their marks . now you have to adjust the tensioner , this is how you do it : turn the crank clockwise twice with the bolt loose now put an allen key in the hole and while holding it tighten the tensioner bolt 43-58 nm do not overtighten or it may break and dont leave loose either . just check with your hand to make sure the belt is tight .
if i remember right the cas has a slot so you cant put it in wrong but you can turn it left and right when its installed so your timing will be right .
try all that and if you have probs let me know .
Thanks wrxhoon.
I did all of that last night. If only i knew the correct procedure the first time around. I aligned the crack pulley's yellow mark with the mark on the lower timing belt cover, and then aligned the dimples on the cam gears with the marks on the backing plate. Then put the belt on using the marks on it as a guide to line up to.
I didn't set it up on TDC last time. I just left everything in the same position from when i last drove it and put the belt on in the exact same place...well that's what i tried to do. My dad helped me do the job but seeing he is a V8 man, all this overhead cam 'stuff' is new to him...lol
Regards,
Scott
is it all done now ? you are very lucky you didnt bent any valves ! is it all back together now ? if you havent got the covers back on turn the engine clockwise a few times and check again all your marks when it comes to tdc and finaky check the tension on the timing belt when all done put together and check timing with timing light .
next time you take the cas out matk its position with paint or something and put together in the same spot so it starts easy and then check with timing light .
Thanks wrxhoon.
Regards,
Scott
wrxhoon,
I have all the covers back on. Should i take the top one off again and turn the engine over to check?
All i have to do now is put all the belts back on and put the radiator back in. Then i will check the timing with the light.
Thanks for the help.
Scott
tdc no 1 is when the crank pulley mark lines up ( 12 o'clock ) and at the same time the 2 cam pullies line up with their marks . if they all line up and the belt tension is right then its all good . did you do the tensioner bolt with a torque rench ? if you dont do it tight enough it will come loose to tight and it will break .
Yep all good now wrxhoon.
Timing is now at 17deg, which is a little more retarded than with the old belt on (I marked the CAS before i took it apart).
Thanks for all the help i really appreciate it. I learnt alot about my car in the process. :(
I will take it for a drive tomorrow and see how she goes.
Regards,
Scott
if you want to set it on 15 all you have to do is turn the cas a little like 1/2 a mm it will move it a couple of degrees .make sure you tighten the 2 bolts so it doesn't move . personaly i would leave it at 17 if it doesn't ping , its got to be 15 @ 650 rpm ( thats the specs )
It says under the bonnet 15deg BTDC @850rpm. I thought it was 650 as well...hrmm
Yeah when i put the CAS back on i set it to roughly the middle and when i started the car and let it warm up it came down to 20deg, so i had to adjust the CAS a little. I'll see how she drives today. :)
Cheers,
Scott
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
