I drive mine weekly(when its working haha) and sometimes to work. The loud car in the carpark is already a thing, idling it would be the next amusement for people. Also who wants to stay at work longer than they have to.
*off to understand oil pre-heaters ....google time.
  On 23/07/2022 at 2:57 AM, joshuaho96 said:
I can't imagine idling a car for 10 minutes any time I want to go somewhere but I'm not really the target audience for a billet block anyways.
Expand
It’s not that hard to waste 10 minutes. Start the car, open the garage, move the car that’s in front of it, remove bollards, check oil temperature gauge and you’ll be pretty close
Sooooo I re-watched this video and I have questions ....
On a second watch this really does look like a video beat up of N1 and sales pitch for braces.
The N1 block is claimed (my understanding)
>Have 1mm thicker deck - Confirmed in video
>Have higher Nickel content ... not addressed
>Be stronger around cylinder 3 and 4 - not addressed other than visual inspection
>Have modified internal water and oil passages for better flow - not addressed other than visual inspection
The video did claim it was less hard, which I thought would suggest it has nickel, as nickel is less hard than cast steel ?
Does hardness really stop a block cracking ?  or is metallurgy a thing here ?
I would of thought a hardness test of a billet block would be 30% less than a cast ?
Also not aware that N1 was ever supposed to be thicker cylinder walls, so that is expected to be the same.
THOUGHTS ???
Expand
Hardness is really not an indicator of compressive or tensile strength. It is somewhat inversely proportional to toughness in that harder materials are usually more brittle. This is one of the key complaints I have with the idea of hardness testing cast iron blocks to determine how "good" they are.
Further, just because there is a different proportion of a given element in a cast iron (yes, iron, not steel) doesn't necessarily mean that any of the mechanical properties of the resulting cast iron will scale up and down in the same direction as the mechanical properties of the element. One of the whole points of alloys is that the alloying elements often to interesting and unexpected things when combined into the crystal matrix. Nevertheless, pure metallic nickel is about 1000 Brinell and typical grey cast irons are about 250 Brinell. So, Ni is not softer than cast iron. Addition of nickel can close on double the hardness of cast irons - if hardness is what you are after. The problem is that nickel is also used to increase high temperature resistance of cast irons, and when you do so, it tends to decrease the hardness. So ask yourself....why would Nissan add more Ni to the cast iron spec for the N1 block?
I would suggest that hardness is not necessarily the most desirable property of a cast iron in an engine block application. Tensile strength and toughness would be higher on the list. Tensile strength only inasmuch as it contributes to the stiffness of the finished casting. The properties relating to castability (how it flows, etc) would likely also be higher. Vibration resistance is an inherent property of cast iron that you would not likely choose to reduce.
Expand
Well, with a billet block being made from aluminium alloys, like 6061, which is only around 100 Brinell. So....
THOUGHTS ???
Expand
At one point Mr Dodge made a comment on his page saying that the N1 blocks are worst than 05U's.
I asked an open question simply from curiosity and wanting to learn, for every handful of N1's or 05U's how many of them crack he got angry and messaged me in a split second demanding I don't ask baited questions
The N1 block was made for cars competing in the N1 Endurance racing series, with a budget to go top level racing so surely some thought went into it regarding what material to use or input of someone clued up.
If you goto a place that has build hundreds of 26's and you want high power likely they spec an N1 block.
There are a few guys who have had a PRP brace on 05U's and ended up with exterior cracks, how well the brace helps a brand new 05U block though, perhaps there's some merit to it.  When I went to build my engine, given an 05U $3500 plus $1500 Brace plus machining plus shop labour, fitting your not really too far off a N1 block price.
Edited by RB335
  • Like 1
Yes @GTSBoy iron, sorry not sure what was going on in my brain.  Thanks for your reply, good info.
I thought iron was 4.5 on Mohs and Nickel 4, making it slightly less hard. Appreciate that is considered a less reliable way of measuring hardness.
  On 26/07/2022 at 11:26 AM, khezz said:
The main lesson in that video is that RB30 is king. $500 a through. Stronger, harder, stiffer and there is no replacement for displacement.
Expand
Yes there is ! Its called money.
I used to think that the "there is no replacement for displacement" was a groovy statement in the day but then I got exposed to the F1 Honda engines of the mid to late 80s.
Changed the way I thought a lot !
  • Like 1
Expand
Love those old F1 videos. Those drivers had balls.
displacement is still king. All 3 of the 6 second gtrs in Australia use 3.2l engines not 2.6l
Don’t know about money. It’s just easier with a 3.2. Look at top fuellers. They use the biggest displacement allowed. No shortage of cash there or brains. But it’s just easier with a bigger motor.
  • 6 months later...
So this was a fun watch.
Seems a lot of value in an N1 block over a standard, specially for the power levels that are not going to split bores(1200 + ?) .
It does make you really question the value of a brace.
He stated the bores are still the problem in the n1 block, it’s the deck and the cracking above the turbo oil feed that’s been improved, also the brace is to stop the main girdle from walking
Expand
He has stated in previous video that the brace was built for 4wd adaptions. Then they noticed blocks crack less. Yes walk is it's feature but also this from the PRP site.
"Aftermarket diffs crack blocks! it’s a fact, the Platinum Block brace will not only stop block twist, but stops the diff snapping the block under load, energy is dissipated through your 40mm thick integrated and webbed brace, blocks cracking and snapping become a thing of the past!"
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
