11 hours ago, Murray_Calavera said:
I hope this helps even a little. So on a 20 - 25ish degree day, my oil temp tracks my water temp by like 10 degrees. So water temp 50 degrees, oil temp 40 degrees. They pretty much rise that way together til they both come up to temp. Water never really rises above 75, oil sits around 90ish.
I run a decent sized oil cooler with a thermostat. Dunno when it opens? maybe around 90ish? No idea.
I also have the factory coolant/oil heat exchanger thingo which helps bring up oil temps nicely.
If you're super curious, I can log data on my next drive if you like.
Me ditto except for not having an oil cooler and not offering data.
15 hours ago, Duncan said:
And to add to that....if you have a dry sump you can get 240v oil heaters for the oil tank which might let you cut a lot of idling time. It can't be good for longevity or oil quality to sit running rich with loose clearances for 12min....
I run a 240V heater in mine, works just like a kettle element. My car spends most of its time gathering dust so when I do get around to driving it I pre heat the oil for 15 minutes and then slip the belt off and prime it with a drill. It's a bit of mucking around but I never worry about cold oil on the out lap although I do have to partially block the oil cooler on cold days at PI to get it up to an acceptable temp within 2 laps.
  • Like 2
I can only go off of the factory ECU logs but a pretty stock RB26 will warm up the coolant in about 400 seconds to 76C from 20C and another 60 seconds to get to 80C. So 6-8 minutes if coolant temps start at about 20C. Oil is probably 2-3 minutes behind, hard to time it exactly because I'm looking at a gauge instead of nicely time aligned charts sampled over Consult.
Also, when the engine is warmed up the power steering idle up switch triggers a straight 8% bump in AAC duty cycle but when the engine temps are cold it's 7%. Not sure why there's this temperature dependence but that's what it is.
I only park hard and hypermile my cars so this sounds like way too much effort, that is a really cool solution to the problem though.
  • Like 1
16 hours ago, The Bogan said:
On all of my cars and bikes, both built engines and standard, I just start them, put my seat belt on, then drive off like Nanna, I've never had an issue
In saying that, they don't get the loud pedal for at least 15 minutes from a cold start
15 minutes is my rule of thumb because I don't have a oil temp gauge
Disclaimer: I'm just assume that my oil, 10w40, is at least matching my coolant temps after 15 minutes of normal driving
What do people who monitor oil temp find IRT how long it takes for engine oil to get around, say, 90°c from a cold start, and what weight oils????
I remember watching some guys at the drags doing maintenance between runs, one thing they did was a oil change, the oil looked like it had the consistency of water
When I talked to him about it he said the engine was built for low weight oil, it was all about power, clearances, oil pump, as well as the oil needed to be thin as it was started, rolled in for a burn out, then launched for the run, all within about 30 seconds, after the run the oil was dropped again as it considered toast from methanol contamination
Yes, that is at the extreme end of performance for oil weights and alcohol contamination, but I did find it interesting, especially as everyone was using E85 in their built daily/cruisers at the time, and spun bearings were a common occurrence 10???? years ago
I assume all the people running billet blocks and big(ish) power are using E85, how often do people change their oil running E85?
I also assume it isn't every 5k km like me on 98
I assume everyone will drink for every time I said assume
Hah, I run a IC7, and monitor my temps IRT. I run a 19 row oil cooler so it takes a while to come up, about 20 mins of street driving in summer time. I baby the car till the temps come up. Coolant temps around 66 degrees by then(Nismo thermostat).
But I cant flat shift till an hour of driving as my box needs to be around 67!!! I run a gearbox cooler behind the rear diff...
Id be lucky to see 1500ks before I drop my oil(pump tune only for now).
  • Like 1
As @The Bogan has a LS I can chime in :D. I have an oil cooler which is blocked on the street by my indicator which I take out for the track.
Generally driving around normally I won't see oil temps above 80 with the cooler, ever. My Coolant will also sit at about that value and fans generally never kick on. However my water temp will get to 80c in about .. two minutes (by the end of the street/1km) whereas oil will take your 20ish minutes to get up to temp. And by "up to temp" I mean 70ish. Start using revs though and this will get to 90-100 pretty damn quickly, and by 'revs' I mean 2500-3000.
  • Like 1
Further anecdote. <10°C ambient this AM. At ~12 minutes after start oil temp was still just under 80°C. So, it would have been >60°C and reasonably safe to give it some load probably ~6 minutes before. Normal stable oil T is 90°C, same as coolant, which should be no surprise with the stock heat exchanger.
  • Like 1
On 03/07/2023 at 4:38 PM, Predator1 said:
I'm guessing this is so your oil temps come up? Or is it coolant temps as well? Do you run oil coolers? What temps do you start driving yours at, and what grade oil?
Oil temp to come up
Coolant temps to come up
Oil pressure to come down
20w60 oil
I'll start driving once oil temp and pressure are within parameters
  • 1 month later...
On 18/6/2023 at 11:44 AM, Butters said:
So this is pretty much my billet block on street nightmare come true, looks like safety's saved him though.
11:34 if your link resets the start point.
I just watched his latest video and he has put the same power steering kit back on the engine, hopefully he has more luck this time
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
