Hi all, my RB26 has been having some engine issues which I think must be a boost leak. I plan on changing the turbo seals to troubleshoot but while I’m in there, what other service items could you recommend? Not looking to spend too much but I want to replace any hoses, seals, gaskets in that area. Intercooler piping is still in good shape.
Engine compression is good and I’m looking to make the motor last as long as possible. Last timing belt service was done in Japan at 110k km, dunno when, but car has 140k now and belts look good
If you mean the oil seals inside the turbo, they won't cause a boost leak, they will only cause an oil leak (generally to the exhaust, leading to massive oil burning smoke from the exhaust).
Other than that, these cars are 30 years old and it has probably done 100,000klm more than the odometer says, and has probably been driven hard at times. If I had just picked up a GTR I would
- Change all fluids (engine oil, gearbox oil, front and rear diffs, xfer case, attessa actuator, coolant, power steering)
- Change all coolant lines (there are kits from places like justjap that include all hoses in silicone, you can go black if you like factory look)
- Change all vacuum lines (this is most likely issue if you do have a boost leak). There are the regular small vacuum lines plus a few larger ones like brake/clutch booster and to and from AAC/IAC etc
- Change the timing belt, and do the water pump, timing belt bearings and bearing idler stud and bolts at the same time
- Put in a new coil pack loom, coil packs and spark plugs
- Change the fuel filter and put in a new fuel pump
- Check for loose or broken studs and if necessary change studs and gaskets for the exhaust manifold to head, manifold to turbo and turbo to dump pipe.
The only problem with that list is you would need to get into all sorts of inconvenient places in the engine bay which can be really tricky unless you are used to it, most likely the job would take many days work and cost lots of skinned knuckles
  • Like 1
Only pull the turbos for service if there's shaft play or obvious oil/coolant leaks coming from it. Ball bearing turbos should have basically zero shaft play. Journal bearing may have a bit of shaft play but only for oil clearances. If you have a boost leak you should test for it first instead of just guessing.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
