On 7/26/2022 at 12:29 PM, BK said:
Mate as you already have the -5, just go with them. At least they are new. Go run 1.5bar and report back if you like them
well, i guess if i run with these turbos on 1.5bar i will have other problems.. like the fuel system as someone mentioned.
Upgrade in turbos goes hand in hand with supporting mods like a fuel system when moving away from a factory car. It’s how it is.
These cars cost ALOT! Open that wallet and watch the cash fly away.
  • Like 2
On 25/07/2022 at 9:26 AM, BK said:
So you bought -5 turbos, no grey zone about it. Pretty far from standard size turbos, as now at a minimum you'll need bigger fuel pump, bigger injectors and completely retune the car obviously with a non standard ECU.
As I've already mentioned, keep these turbos you NEED to do this. Not optional, need to.
For some reason it sounds like you still think you can keep these turbos based around everything else completely factory.
Ain't gonna happen
  • Like 1
Last time I remember seeing on here you'd spent money we were still using Pounds....  😁😁  You still playing or what?  Says me who hasn't driven a GT-R for ten years.....  Fuel was $1/L last time I put fuel in it....
I will try to change them to a smaller refurbished or new ones from a local store or something. It's a bit stupid to run this big turbos when im only want to run factory power.
Dont do it, a factory power GTR is shit. No really- it is really, really shit. None of us bought a GTR to run the standard 160 -170kw at the wheel factory power output.
GTR comes alive at 300kw at wheels and up, which you me is where they should've been released at.
  • Like 1
On 7/27/2022 at 11:04 AM, BK said:
Factory power GTR is shit. No really- it is really, really shit. None of us bought a GTR to run the standard 160 -170kw at the wheel factory power output.
Okey. so how far can you go on these Rb26 engines safetly? Stock head and bottom. ( There are new rods, pisonts ( eagle and cp), crankcollar etc but do not want to push anything. I talked to a tuner who told me that these turbos Gt2860-R are great for street use and have fast spool on lower boost. I guess i could run these anyway and go for a bit more power then.
I have a link G4 ecu from a R33 GT-R, this one should work? I talked to link but they  couldnt confirm it, so i checked the pinouts with the link g4 software which only have a general pinout label for GT-Rs so i belive they are the same for r32 and r33..
Theyll take 300-330kw at the wheels without breaking a sweat, most of us have pushed standard engines well past that
any aftermarket ecu that works on a 33 will work on a 32 and vice versa
  • Like 1
Okey, thank you.
Well then i will take a closer look at this ecu. $500 is pretty cheap compared to a new one.
On 27/07/2022 at 7:55 PM, timmy94 said:
Okey, thank you.
My R33 is 330kw / 450hp at wheels on pump unleaded - completely unopened long engine. Basically fuel pump, 700cc injectors, Z32 AFMs, adjustable cam gears and 22psi boost on the far outdated Power FC with ball bearing HKS GT-SS turbos. (-9 Garrett equivalent)
Runs mid 11s at around 118 -120mph and is a motorkhana weapon.
  • Like 1
On 7/27/2022 at 1:27 PM, BK said:
Forgot add decent 3.5 inch exhaust and 100mm intercooler.
Okok.
Well there is some kind of 3" or 3.5" exhaust with 5" blitz muffler on. Intercooler is standard on mine, as well as bov etc..
How does that power fc work? And trigger upgrade, isnt that necessary?
I talked to the guy with the G4 Link, i could get it for 450 instead of 500, seems fair for that ecu?
Apexi Power FC is just a full replacement ECU we all used 15 - 20 years ago, allowing boost control, fuel and ignition tuning. They work well if you dont need anything outside of what they can do, and is why that car is still on one. On the single turbo cars with 4 bar MAP sensors, flex fuel, crank triggers and custom sensors I'm on the Haltech Elites.
Link G4 will be fine for what you want and will fit in factory location. No you won't NEED a trigger kit even though they are better.
Yes i know its replacement ecu but ive heard that some verisions of those were not good at all. Was just curious what you thought about them
Thanks 😄
The g4 card.
Edited by timmy94
The tuner who told you GT2860R has fast spool on low boost was referring to -7.  Both -5 and -7 are GT2860R, but they are at the opposite end of capacity.
If the HKS that came off have no shaft play nor oil leak, why not put them back on?  A pair of HKS oil restrictor cost little.  Perhaps send an email to HKS, if lucky they may be able to decipher the part number.  If they are really the GT25 series, then they are the streetable turbo you are looking for.
I think i was clear about -5, but idk..
Hks couldnt identify them by the plate.. still figuring out which ones it is. It has a little play in shaft but idk whats accepteble cause all turbos seems to have a bit of play when there is no oil pressure. There is no chafings in the housings..
Ok. So its either stick with these turbo run 300kw, new injectors and pump + link ecu
Or
Send the hks ones for service check and put link ecu on the car and dont bother of anything else. I guess the link ecu is a good option either way
Yes the Link is a good option no matter which turbo you end up.  With the -5 it will be more involved than just injectors and pump.  As others mentioned you also need new sensors to measure air flow, either MAP or MAF.  There are many fuel pumps available, but figuring out how you want to setup the wiring to supply the pump is another level of headache.  You can find plenty of discussion on that here.
  • Thanks 1
Okey. Its the headache i want to skip on this build. Just want as simple build as possible  so i can drive around the street buy some ice cream, do some roadtrips and just enjoy the car as it is. A bit more power wouldnt hurt but nothing more too fancy shit here, since the Silvia S15 went a bit crazy.
I will try to read through the forum as much as possible.
I am skeptical that your HKS turbos are the Garretts they rebranded for a while. If you want a "simple" turbo I recommend the GT2860R-7. Nismo resells these turbos as the R1 turbo kit, they have released an R3 turbo which supposedly yields slightly better response. These were the ones used in the R34 N1 cars which will do around 450-500 crank hp. The only turbo I know of that is smaller than these N1 turbos is the HKS GTIII-SS. It is a journal bearing Mitsubishi turbo so nothing special.
If you want the absolute simplest solution then stock ECU + R34 stock ceramic turbos are my recommendation. No tuning required at that point.
Edited by joshuaho96
It's worth noting that any tunable ECU will do what you need, but the PowerFC and Link G4 are direct plug in, while others like Haltech Elite will require custom wiring or an adapter at extra cost. Either way, the cost of tuning will be the same or more than the cost of the ECU, so you should find a tuner you trust first, and then buy the ECU they are familiar with.
PowerFC is very suitable for low-mid power like you are talking about, plug in and drive off, and very quick to tune because there are less parameters than more modern ECUs.
The problem with where you are right now is you are trying to work out a way forward based on what you have on your bench, rather than having a target power and buying the right parts to hit that. Any turbo more than about 10% bigger than standard requires many additional parts (and costs add up quickly).
If you are looking for a pretty much standard experience without unnecessary cost, I'd be getting the HKS turbos checked and putting them back on with a standard ECU, and run standard boost. Anything other path will be 10x or more the cost.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
